Question about Jabsco 50880 1000 Marine Filter Less Shower DrainBilge Pump
Hi. my problem is that my pump ( 50880-1000 shower drain), doesn't drain any more. the float is fine, it works, but when the drain pump float switch is in the up position, the pump won't **** the wather, it used to sound like it was hard to be done for the pump and then it just even try any more. thank you
    Problem Solver:
  • 19 Answers
Remove the float switch from the circuit and try it again with direct power.
The switch could have a fault , at first as it was failing it may have been a resistance issue within the switch and now it has failed. OR Could be a blockage
Posted on Aug 26, 2010
I have the Johnson Viking Power 16 Waste Pump installed. It says in the manual that it is fully self priming up to something like two or three meters. I have maybe a 70 cm difference between the shower and...
"Does not want to start again". As in the motor does not turn on or as in it doesn't pump the water out?
The lines from the tank to the pump have to be air tight or it will not be able to "draw" the water due to all the air getting in the line. From the pump to outlet, not quite as important except you really don't want water spraying everywhere so should be fairly tight and sealed.
If it is using a float switch to start the motor, make sure it is working properly.
Sep 29, 2012 | Johnson 10-13350-03 Viking Power 16 Waste...
Dishwsher doesn't get disher clean
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Hoover 24 in. DT999 Free-Standing...
Gu1200xlkb0, water left in tub after wash. Checked hose for clog. Drain pump working. Drain loop check valve functioning.
Hello & Welcome to FixYa
If the drain pump is taken apart and cleaned completely then the problem can be with the float switch. You have to take out the bottom front panel out and then clean the drain filter pump assembly completely. Please get back to me if you have any other questions.
Kevin
Jun 28, 2011 | Whirlpool Dishwashers
ESL624 dishwasher. On any cycle the machine stops after about a minute or 2. Its as if it cuts out for some reason, It pumps out but it doesn't get to the point where it starts letting water in....
Hi
Daniel
Jun 28, 2011 | Electrolux 23 in. ESL624 Built-in...
Dishwasher drain pump continues to run constantly and does not progress onto a wash cycle. I've unplugged, pulled the unit out and removed the LH panel. Taken off the side tank and the lower mounted...
You have provided a very detailed explanation of the problem. You will have to check if the spring in the float is ok. May need to replace it. Cheick this.
Jun 24, 2011 | Neff 24 in. S5457X0GB Built-in Dishwasher
Occasionally my Saniplus pump runs but doesn't drain. It seems to happen when there is a moderate amount of bubbles created. i.e. when I have showered with a shower gel and the gel foams up to create...
This sounds as if you have a venting problem if there is no air introduced into system then it cannot drain,even with a pressure pump system,the only other thing is that the pump and grinder system is faulty,if still under warranty contact mftr.
Jun 19, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
I have changed the pump, the check valve and cleared the drain hose but the unit does not drain. model# DU1055XTSS2
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it.Hope this helps...please post back for further assistance.
Daniel
Jun 08, 2011 | Whirlpool Dishwashers
Can I ajust the pump to turn on sonner . Some small water back up in shower .until pump turns on.would like to ajust pump level on / off thanks
You will need to get into the pump float area and there should be a float ball that can be adjusted. So the answer is yes.
Mar 06, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Liberty condensate pump LCU-20S never shuts down and is loud
Had the same problem today. What I did to fix this was to disconnect the unit and shake it so that the float became free. Once this was done, I reconnected the power and drain tube and PVC lines and primed the pump with about 32 oz of water to activate the pump. All works fine now.
Mar 16, 2009 | Liberty Condensate Pump 20' Safety Switch...
Jabsco 50880 1000 Marine Filter Less Shower DrainBilge Pump Logo
105 people viewed this question
Top Jabsco Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Jabsco Boating Expert? Answer questions, earn points and help others
