Dell blank screen
Hi I need someones help before i go and spend money somewhere.
My laptop bag fell off my porch the other day (about 2 feet up) and now it will turn on and i can hear the windows startup but my screen is a dark blue color is there anything i can do?? Or is my screen just busted??
Anything will help thank youu
  • 5,568 Answers
Don't like to disappoint you but there are so many possibilities for failure after being dropped, I don't think anyone here can help you without having your unit in hand for inspection.
One thing you might consider doing yourself:
You apparently have another computer available.
If it is a desktop, (locate one in any case), follow the cable from the monitor to the system box backside.
Not the cable that goes to the wall or powerstrip, the one that attaches to the system.
Detach the cable from the desktop's system box (should be two thumbscrews) and find the mating connector on your laptop.
Be gentle - the pins are fragile.
Turn your laptop on and watch the desktop's screen for signs of life.
If you see anything recognizable (text, wallpaper, etc.) then your laptop has survived up to the screen section.
Ths means you could at least retrieve data from it so as not to lose your work.
I don't recommend trying to peer inside your laptop, the cases don't always come apart easy and you may not know what you are looking at even if opened.
Laptop repairs are not cheap or always lasting so you might consider getting your docs off of the machine or just buy a cheap monitor and make your laptop - a desktop.
Good luck-
Posted on May 05, 2008
Z221 blank white screen
I need help with my Zte z221 flip phone. It fell into water on accident and then the screen white and I tried to fix it. What can I do without spending money to get it repaired?
Jul 07, 2012 | AT&T Cell Phones
Dell Vostro 1510 laptop screen is blank. If I hook it up to an external monitor, it works on the external just fine, but no display on laptop LCD. I had it in the shop for intermittent display probs 4...
It is definitely possible you have a damaged screen component. At this point I would recommend taking it to a service center or call them and have it shipped for repair. You may even have a local computer repair shop that could help you out and maybe save some money :)
The problem has been narrowed down by connecting it to the TV. We know the laptop works fine otherwise except for the screen.
May 05, 2011 | Dell Vostro 1510 Laptop
My sensa fell in water and the screen went blank, i dried it off even blow dryed it but no screen yet, what should i do????
hate to say it. unless you can afford to spend the money to have it repaired. you may want to buy a new one
Aug 20, 2010 | SanDisk Sansa e250 MP3 Player
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Jul 21, 2009 | Sport & Outdoor - Others
Dell Inspiron 5160 screen is very faint
u need to update ur laptop BIOS or change it
Jul 14, 2009 | Dell Inspiron 5160 Notebook
Black screen fell into water and not working
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
May 30, 2009 | LG Secret ? KF750 Cellular Phone
Screen goes blank when on battery power
Two possibilities: The display is a power hog. It's possible that the battery is failing, and has enough power to run the PC, but not the PC AND display at the same time. You would need to replace the battery, in this case. Or, in Control Panel, in Performance and Maintenance, in Power Options, there should be settings somewhere for the display when on battery or AC power. Make sure that the one for Battery doesn';t turn the display off after 0 minutes.
Mar 03, 2009 | Dell Inspiron 1521 Laptop
Wireless connection
On your router seei if you have the ability to setup a PPTP VPN connection. Grant your friend access and share the folders for him/her
Jan 13, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 Pentium M blank screen
Above is the directions of how to get to the video board:
I would check the LCD connector first.
Here is the service manual for it.
It will show you how to take it apart.
Please let me know how you make out.
Dec 26, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
