Question about Maytag PYE2300AY Electric Dryer
I have a maytag pyg2300ay. when replacing the belt, do 'both" sides of the new belt run under the tensioner wheel? if not what is the proper alignment?
  • Maytag Master
  • 3,051 Answers
Hello there:
It should be routed like this i have a maytag pyg2300ay.
Posted on Aug 25, 2010
  • Michael Thomas
    Michael Thomas Aug 25, 2010
    as long as the belt is on the pullies as shown and looks fairly close to being straight on the drum and pulley's... once the dryer is started it will align it's self as needed
How can i replace fan belt for a 2000 ford focus 16 v zetec and how the fan runs on polley?picture show.
      • Things You'll Need:
      • Wrench set
      • Jack
      • Jack stands
      • Socket set
      • Ratchet
      • 1/2-inch drive breaker bar
    1 Open the hood of your Focus and locate the negative battery cable at the battery. Loosen the clamp bolt on the battery cable end with a wrench, then lift the battery cable off the battery terminal. Isolate the battery cable from the battery terminals by tucking it off to one side.
  • 2
    Position a jack under the front of the car and raise it off the ground. Support the car with a set of jack stands, placing them under the front suspension. Lower the jack until the car is resting on the jack stands.
  • 3
    Locate the splash shield in the passenger's side wheel well and remove the two retaining bolts that secure it, using a socket and ratchet. Remove the splash shield from the wheel well and locate the serpentine belt tensioner through the access hole.
  • 4
    Insert the square drive of a ½-inch drive breaker bar into the square hole on the tensioner and rotate the tensioner counterclockwise, releasing the tension on the belt. Remove the belt from the pulleys and rotate the tensioner back to the home position.
  • 5
    Position a new belt in the engine compartment and run it around all of the pulleys except the tensioner's idler pulley. Rotate the tensioner counterclockwise with the breaker bar and then slide the belt under the idler pulley.
  • 6
    Slowly rotate the tensioner back to the home position, tightening the belt as you rotate it. Remove the breaker bar, then replace the splashguard in the wheel well. Install the two retaining bolts and tighten them with a socket and ratchet.
  • 7
    Raise the front of the car off the jack stands with a jack, remove the stands from under the car, and lower the car to the ground. Install the negative battery cable on the negative battery terminal and tighten the clamp bolt on the cable end with a wrench.
  • Nov 30, 2010 | 2000 Ford Focus
    I want to replace the belt because when i open the dryer from the back i got the belt & its cut. my problem is how to replace a new belt since the back side is blocked. i unscewed the front &...
    You should do it from the front.Remove the front panel.drum sits on bogey wheels.take new belt place it around drum.Take belt and swing tensioner pulley and slip belt over tensioner pulley.The pulley moves up and down once you adjust belt around pulley and release it belt should ride properly tight on drum and that should do it
    Nov 07, 2010 | Dryers
    How to replace the alternator on a 2003 Mazda MPV
    Disconnect the battery at the positive terminal by turning the bolt counterclockwise. Disconnect the alternator's terminal by turning the nut counterclockwise and removing the loop from the terminal bolt. Store these connectors away from the battery.
    Remove the belt by pressing on the tension pulley arm firmly, then sliding the belt form underneath the idle pulley wheel. Release the tension pulley and the belt will slacken; it can then be removed from the alternator pulley wheel.
    Remove the alternator by turning the mount bolts counterclockwise, then sliding them out of the mount arms. Some models may have mount bolt heads that must be held in place with a wrench while turning the nut. With the mounts free, the alternator can be exchanged for a new unit. Position the new alternator into the mount arms and slide the mount bolts into place, locking them down with the nuts turned clockwise.
    Wrap the drive belt around the alternator pulley wheel (groove side down), then press the tension pulley arm and slide the belt back under the idle pulley wheel. Release the tension arm and the belt will automatically adjust to the proper tension.
    Reconnect the alternator's terminal loop by placing it over the bolt and turning the nut clockwise. Connect the battery by turning the positive terminal bolt clockwise.
    Oct 21, 2010 | 2003 Mazda MPV
    We had a new serpentine belt replaced a couple of months ago and it just came off. How can I put it back on? Also the lug nuts seem to be stripped.
    Click on the following free direct Link. It has the Serpentine Belt Diagram and Tensioner location for your 2000 Saturn SL.
    http://www.2carpros.com/car_repair_information/year/2000/make/saturn/model/sl/2000_saturn_sl_drive_belt_routing_diagram.htm
    Before we get to putting it the Belt back on...
    Look at the alignment of the Pulleys. Most times the Tensioner or Idle Pulley are "canted" - meaning pitched or leaning forward, which causes the belt to "run off" the pulley - throwing the belt.
    With the Belt off: check side-to side play for each one of the Pulleys by hand, especially for the Tensioner and Idle Pulleys. There should not be any side-to side play. If there is any other Pulleys that are canted - check if they are properly tightened. A new belt should not have come off on it's own without some other problem.
    GENERAL/Standard Rules to Removal the Serpentine Belt with a Tensioner:
    A. Find the Tensioner(s). (See Diagrams on Link)
    B. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
    C. Remove the loosened belt off one of the other more easily accessed Pulleys.
    D. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
    Standard Rules for Installing the Serpentine Belt with Tensioners:
    a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
    b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
    c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
    d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
    e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
    Regarding the Strip Lug -Studs.
    Is this on the wheels with Rotors (Disc) or Drums? If the tire was not properly mounted, or the Lug Nuts were not properly Torqued; this will cause the Lug Studs (bolts) to be stripped.
    With the vehicle raised and properly supported by jack stands:
    For Rotors:
    Remove the Tire, Brakes (Calipers/Pads) and Rotor, exposing the Wheel Hub (Bearing) Assembly with the Studs fully exposed. Rotate the Wheel Hub to a location where the Lug Studs can be clearly removed FROM THE REAR OF THE WHEEL HUB ASSEMBLY.
    Using a impact hammer or mini sledge hammer: Hammer the Lug Studs back thru the Wheel Hub Assembly.
    Remove the loosened Lug Studs.
    For Drums:
    Raise, support, remove the Tires.
    Remove the Drums off the Wheel Assembly.
    Using a impact hammer or mini sledge hammer: Hammer the Lugs back into the drum, removing from inside the Drum
    Purchase the new, correct size and length Lug Studs and new Lug Nuts. If the Studs were stripped, most like the Nuts are too.
    To reinstall the Lug Studs: Purchase an additional two (2) Lug Nut that fits that Lug Stud. Also purchase several Large Heavy Duty Washers that can fit on the the Lug Studs.
    Place the Lug Stud back into the Wheel Assembly from the Rear (Rotors) or from inside (Drums). Use High Temp Grease for the area of the Lug Stud Splines that have to be "drawn" into the Wheel Assembly (with Rotors) or into the Drum.
    After the Lug Studs are "IN" as far as they will go: on the outside place at least two (2) of the Washers on Lug Studs. Use a Lug Nut and tighten as far as possible down-on the Lug Stud as possible.
    Next: Using an Impact Wrench tighten that Lug Nut down/on, drawing the Lug Stud into the Wheel Assembly/Drum. Check the rear of/inside the Wheel Hub Assembly/Drum. The Heads of the Lug Studs should be firmly against the Wheel Assembly/Drum.
    If you do not have a Impact Wrench - use at least a 24-in Breaker Bar and Tighten the Lug Nut on, drawing the Lug Stud into the Wheel Hub Assembly/Drum. This takes longer and alot more work, compared to 10-seconds using the Impact Wrench.
    Repeat as necessary.
    Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
    Mar 31, 2010 | 2000 Saturn SL
    Need belt diagram for Performa PDET920AYW dryer
    Flat side of the belt goes agaist the drum. The diagram is on the new belt
    Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
    Timing belt
    You obviously need to replace your TPS, and you may need a new belt tensioner as well. On these cars the timing belt setup is not about no 1 cylinder being top dead center. Here are the proper steps to do a timing belt on this vehicle:
    To change the timing belt first place the right side of the vehicle on a jack stand and remove the right front tire. Remove the plastic cover inside the wheel well to expose the harmonic balancer. Remove the serpentine belt (standard 3/8" rachet will set in the belt tensioner to relieve tension). Remove the harmonic balancer (19mm). Place a jack under the engine on the right side of the vehicle, then remove the engine mount from the top of the fender well, (17mm deep well socket and 17mm wrench required) it is not necessary to remove the mount from the side of the engine. Remove the timing cover, (10mm) it has 2 nuts. Loosen the timing belt tensioner, (10mm) then pry it away to relieve the tension. Slide the timing belt off of the cam gear.
    To position the new belt, the cam gear has a arrow on it, and the cylinder head has a small dot. Align the arrow with dot, and make sure it is aligned (the arrow must point up). The crank gear has a notch and the engine has a groove to align the notch. Again, make sure the notch and groove are aligned (they again will be up). Place the new timing belt in position around the crank gear, the water pump and belt tensioner and leave the slack at the top. Again relieve any tension from the belt tensioner, and slide the belt on to the cam gear. Place a slight bit of tension on the belt and tighten the belt tensioner. Use the 19mm bolt from the harmonic balancer and turn the engine 2 complete turns and verify that the cam gear and crank gear are in their proper positions and aligned with the dots and notches. After 2 complete turns of the engine, and verifying everything is still aligned, re-assemble in reverse. No further adjustment is necessary.
    Note:There is no timing adjustment for this vehicle, and if you are not properly aligned on the cam gear and crank gear it will not run properly.
    Apr 29, 2009 | 1996 Ford Escort 4 Door
    Timing
    There is no timing adjustment "at all" for a 1999 escort. If your timing is out, your timing belt has slipped and needs to be replaced.
    To change the timing belt first disconnect your negative battery cable, then place the right side of the vehicle on a jack stand and remove the right front tire. Remove the plastic cover inside the wheel well to expose the harmonic balancer. Remove the serpentine belt (standard 3/8" rachet will set in the belt tensioner to relieve tension). Remove the harmonic balancer (19mm). Place a jack under the engine on the right side of the vehicle, then remove the engine mount from the top of the fender well, (17mm deep well socket and 17mm wrench required) it is not necessary to remove the mount from the side of the engine. Remove the timing cover, (10mm) it has 6 bolts and nuts. Loosen the timing belt tensioner, (10mm) then use a 3/8" rachet in the belt tensioner to relieve the tension. While relieving the tension slide the timing belt off of the cam gear.
    To position the new belt, the cam gear has a arrow on it, and the cylinder head has a small dot. Align the arrow with dot, and make sure it is aligned (the arrow must point up). The crank gear has a notch and the engine has a groove to align the notch. Again, make sure the notch and groove are aligned (they again will be up). Place the new timing belt in position around the crank gear, the water pump and belt tensioner and leave the slack at the top. Again use a 3/8" ratchet to relieve any tension from the belt tensioner, and slide the belt on to the cam gear. Place a slight bit of tension on the belt and tighten the belt tensioner. Use the 19mm bolt from the harmonic balancer and turn the engine 2 complete turns and verify that the cam gear and crank gear are in their proper position and aligned with the dots and notches. After 2 complete turns of the engine, and verifying everything is still aligned, re-assemble in reverse. No further adjustment is necessary.
    Mar 29, 2009 | 1999 Ford Escort
    How do I locate tension wheel to replace serpntne belts 04 sentra
    The serpentine belt runs everyting under the hood...easiest way to locate the tension wheel is to look at every other wheel that the belt runs to.
    Your tension wheel will be where the belt runs without being in a V channel, the tension wheel will be flat..no grooves to accomodate the belt.
    Hope this helps
    Feb 01, 2009 | 2004 Nissan Sentra
    Drive belt needs replacing on Hotpoint TC71P
    how do i get my tension correct on a hotpoint tc71p
    Jan 19, 2009 | Maytag PYG2300A Gas Dryer
    Put dryer belt on maytag dryer
    generic maytag dryer belt replacement
    type 1:older models by Maytag with lintscreen under door
    • unplug dryer
    • remove 2 screws from under front panel
    • tilt front panel up from the bottom and unclip top
    • remove door switch wires
    • set front panel aside
    • remove front drum retainer 2 screws each side
    type 2:newer models by whirlpool lint screen in top cover
    • unplug dryer
    • remove lint screen
    • remove 2 screws under lint screen
    • with putty knife or other blunt blade
      unclip spring clips at front corners of top panel
    • remove 1 screw each side of front panel 1/2 way from top
    • remopve door switch wires
    • tilt front panel down and unclip
    all
    • withdraw drum forward
    • examine drum rollers for wear
      if worn or locked replace in pairs
    • examine felts and nylon glides(if fitted) for wear
      if worn replace
    • examin case floor for tensioner
      (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
    • loop new belt around drum at wear mark of old belt
    • insert drum
    • loop belt around motor pulley
    • pull tensioner to end of travel against spring
    • loop belt around tensioner
    • relax tensioner
    • rotate drum by hand to make sure belt wont jump off
    reassemble in reverse order
    Oct 29, 2008 | Maytag Dryers
    Maytag PYE2300AY Electric Dryer Logo
    19 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
