Question about Toro Lawn Mower With Toro Power Tools
I have a new 2010 Toro 22" Recycler that has the 190cc engine and key start. The mower starts and cuts fine, but after about 5 mins it shuts off and I have to wait about 2 minutes to start it back up. Once re-started, it does the same thing. A neighbor told me to change the spark plug, which I did and it didn't do any good. Please halp!!!!! Thank you. Tim Hall 773/495-6876
  • timothy_j_ha Aug 25, 2010
    Very good and sensible reponse!
    Thank you.
    Tim Hall
    Thanks, makes sense and I will check it tonight.
    Tim Hall
  • 2,973 Answers
Tim,
The problem is not with the plug. But with the ignition coil. It gets heated up and quits. Starts again when cooled and this cycle continues. Please replace the ignition coil. It is the coil from where the thick lead goes onto the spark plug.
Posted on Aug 25, 2010
How to fix stuck pull cord of a 22 inch Toro Recycler lawn mower
Is the engine seized?. Try turning the blade and if it won't turn then you have a seized engine. If that is ok your recoil has a stuck part possibly something has broken off inside. If it's an older model try shooting WD40 inside the recoil as it could be rusty.
Jul 25, 2014 | Toro Garden
I have a toro recycler 6.0 push mower and I can't seem to get it started changed the plug but still won't start
get the old gas out of tank and carb....put new gas in...wait 2-5 min....spray starter fluid into carb --one decent squirt....it'll crank....
Jun 09, 2014 | Toro Power Lawn Mower
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
Toro recycler self propelled 6.5hp, 22" (gts) 2010
Hi Wahid
You probably sheard the flywheel key...
You will need to pull the flywheel off and replace the sheard key to be able to start the motor again.
Please take time to rate me
Bud
Mar 18, 2013 | Toro Garden
Toro recycler mower w/electric start is leaking oil
Blown oil ring. Rebuild or replace engine. Remove spark plug if oily bad rings. Harbor Freight sells 160cc or 190cc replacement engine, Northern Tool also sells engines. Check for proper bolt pattern mounting. Remove blade and cables to carb and replace engine.
Jul 30, 2012 | Toro Power Lawn Mower
Engines dies after 5 seconds
loosen the fuel cap and try running it the vent in the cap could be plugged up
Jun 11, 2012 | Toro Super Recycler Super Bagger Lawn...
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
I can't pull the pull string on my lawnmower and it seems oil is leaking out of the side. i don't even know where to find the sparkplug! i am handy, but this lawn mower is completely alien to me. i have a...
have you tipped mower over at any stage? oil will be in a/c and cyl/head ...any time you tip mower pull high tension lead off s/plug and tip mower so that spark plug points to the sky...you will need to remove spark plug (suspect it will be full of oil) replace air cleaner....and retop up with correct oil...
Jun 21, 2010 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
400 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
