Question about New Balance 1400 Treadmill
My New Balance 1400 treadmill has an error message number 4. I have turned it off and then back on and it still comes back with error message. I have taken the safety key off and back on still the same. Have unplugged it and back on still nothing. How do I fix it?
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: I have a New Balance 1400 Treadmill. I turns on
I have a Horizon Treadmill that had the same error, it turned out to be a calibration using the adjustments on the logic board. The New Balance does not show the calibration procedure, but you can call 800-497-5831 for service. Hopefully it is still under warranty.
Posted on Jan 26, 2011
maxtreadmill
  • 832 Answers
SOURCE: My New Balance 1400 treadmill
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
Posted on May 09, 2011
I have a New Balance 1400. How do you do a hard reset on it?
In almost all treadmill error 1 denotes the speed sensor error.
In you case I suspect there is some variation in the alignment of the speed sensor. May it moved away from the magnet Which is fixed on the rotating wheel. Try to make it closer as much as it can, be sure not to keep a small distance .hope it will solve the problem.
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | New Balance 1400 Treadmill
I have an older NB 1400 Treadmill (7 years old)
Motor controls for New Balance can be found by doing a Google search on Treadmill Analyzer and look for the MCB List page of repairs offered :-)
Jul 15, 2014 | New Balance 1400 Treadmill
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
The belt on my New Balance 1400 has become kinked up. I tried adjusting it by loosening it up, straightening it out, then tightening it back up, but it kinks up again. Before it kinked up for the first...
Unfortunately once the belt has a crease that all she wrote. Belt replacement is the next step.Call Fitness Quest they are the makers of your treadmill @ 1-800-321-9236
Jul 31, 2010 | New Balance 1400 Treadmill
I havea new balance 1400 I keep getting two error codes on my screen the first is E1 and then A E3 on elevation.?
Hi This is dinesh here,
The E1 Error is for the sensor problem and the E3 error is for the IC crasg in the machine...
Jul 22, 2010 | New Balance 1400 Treadmill
Life Fitness T3 treadmill won't turn on. Power from outlet is fine. 4 red lights are on by motor under front floor panel. Tried resetting, per owner's manual (pressing Stop and Down Speed), but nothing...
Could be. If you had to take it apart, I would definately check the wire harness connection. Also if there are bolts that were removed, check to make sure none of those pinched the harness when reassembling.
Nov 17, 2009 | New Balance 1400 Treadmill
What kind of lube do i use
There is a special wax designed for treadmills proform part number 219167.at sears parts online Or treadmilldoctor.com has lube kits you can purchase from them.
Jul 29, 2009 | New Balance 1400 Treadmill
Treadmill Won't Start
you need a new lower board from the mfg. you can replace this item you self if the make the part still call them.
Apr 18, 2009 | New Balance 1400 Treadmill
New Balance 1400 Treadmill Logo
61 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
