Question about Frigidaire Kitchen Ranges
Model PLE399ECI...everything works except the stove top part....dials work, digital numbers show up but no heat
  • timbettis Aug 25, 2010
    This is a glass top model and none of the heating elements work. Everything else works fine.
    Genius:
  • 1,416 Answers
what this indicate is that there have been a loose of wire connected to the heater (element ).
what you are to do to fix up this problem is to unscrew the range then trace the wire down to the that same stove that have fail to carry out it function see if there is any loose wire that expected to be connected to the stove ,fix it up to it to be sure but if there is no loose wire is then means that the wire that carry out it function (power) to the stove has gone bad which will need a replacement ,you can get this wire from the any technician shop around you please note when ordering for a new wire make sure that it same type and size for easy fixing or compatible .
thank you and thanks for using fixya.
Posted on Aug 25, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Please check the link bellow regarding your query…
http://www.ehow.com/about_6321062_stove-top-burner-problems.html
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
My oven does not heat up. Everything else on the stove works (top burners, clock, timer, ect.) When you turn the oven dial, it even clicks as if it were to start the oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 10, 2011 | GE JGRP17 Gas Single Oven
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
All the dial lights work and clock works but over or stove will not heat up.
check for 220v to the stove. if it is only getting 110v it will do everything but heat.
Jun 18, 2010 | GE Spectra JBP78 Electric Kitchen Range
Everything is working except the timer is not
Suggest you replace the timer dial, this should do the trick.
Oct 06, 2009 | Whirlpool Dryers
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
41 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
