Question about Vacuums
Can you send me a La Cimbali M22 Premium espresso machine power switch wiring diagram? I have a machine without a power switch. The switch is on order but I still have to connect the 10 loose wires. Thanks, Terry...
b0sslady2001
  • 357 Answers
SOURCE: G4 Footswitch wiring
I have published an online guide...it may be of help to you. Just click on the link to view it.
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Posted on Oct 16, 2007
reddevil6
  • 1673 Answers
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Posted on Jan 31, 2008
SOURCE: Need a wiring diagram for a Filter Queen D31X
I need to make a filter
Posted on Feb 11, 2009
FitzOriginal
  • 842 Answers
SOURCE: NO POWER
The problem is almost certainly a fatigue break in the flex. These usually happen where the flex enters the handle through the rubber sleeve near the on off switch. You will need to cut about four inches off the wire and reconnect it to the switch. To do this, you need to remove the on/off button as you have suggested. If you press the green button down, you will see a tiny slot at the side of the button on the side nearest the handle of the cleaner. You will need to slip a small screwdriver with a blade about 3-4 inches long down the slot, in order to disengage the little hook at the bottom of the button moulding that clips it into the body of the cleaner. This is a real fiddle and you will probably mark the casing in the attempt. I have done it dozens of times and I still end up shaving off the ridges I have made in the plastic so the button doesn't stick when I reassemble it! Once you have done this, you can draw the buttup upwards and take it out. This will reveal a philips screw holding the switch button in place. Unscrew and remove the switch, then cut and re-make the connections after removing the 4 inches of flex. You will need to replace the spade connectors on the wire, or cut, solder and insulate the re-joined wires before re-assembly. If you are handy with a solder iron or have some small spade connectors to use, go for it, but be sure you are competent to make this repair. Usual rules for dumb people apply her folks. UNPLUG from the mains before you start tinkering around!
Posted on Mar 13, 2009
  • 157 Answers
SOURCE: Replaced Oreck power switch. 2
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Posted on Nov 03, 2010
Testimonial: "I think Oreck used the white connector on the lighted switch for power. I must have tripped the breaker a dozen times with a short."
Electrical troubleshooting for dyson dc25. How to connect wiring correctly.
Request the wiring diagram for the DC25 from Dyson OR take it to a vacuum cleaner repair shop.
May 03, 2018 | Dyson DC25 All Floors Bagless Upright...
All these answers deal with changing the belt. The belt on mine is fine. The light for the brush head doesn't come on - it's not getting power or the motor is burnt out. Next step?
What kind of vacuum is it? Model number? If its a canister machine and its not getting power to the nozzle its possibly: 1)One of the connections in the handle or the connection that sends power through the hose at the canister end is faulty. 2)If the hose handle has a switch to activate power on and off that may be bad. 3) The hose itself has a break in the internal wiring and would need replaced. However, this can be tested by powering the machine on and flexing the hose around to close a wiring break and see if it kicks on for a moment. 4) If the power nozzle has a circuit board brain in it that may have failed. 5) If there's a reset switch at the nozzle give that a try.
Sep 30, 2017 | Vacuums
Wiring diagram
The only place I know of fora wiring diagram for a Guardian is at the local branch office. The new name for the Electrolux is now AERUS.
Check your phone book.
There is a fuse wire that runs from the cordwinder to the triac circuit board inside the vacuum canister. You have to take the six screws out of the bottom. Open the bag door and lift up on the top handle to remove the top part.
It is vere advisable to take your vacuum to the branch office that has a qualified service manager. You can do more harm than good on the inside of the machine.
Jul 22, 2014 | Electrolux Guardian Bagged Canister Vacuum
I nead a wirring diagram to fit a four connection power switch to a Kirby G4 cleaner
There isn't a wiring diagram for these. There is only a switch, a motor and a light, so a schematic isn't really required.
I'm assuming you've made the fatal mistake of removing the wiring from the old switch and have forgotten where to re-connect them. It's also not very helpful that all the wires are white, so I can't really tell you to connect red to "x", black to "y", etc.
The really important connections are the power cord and the motor brush connections. You can't get the power cord wrong as the plug is shaped to only allow connection at one orientation: I've drawn you a diagram to show 3 of the 4 connections:
As long as the motor brushes are correct, there wont be any problem. If these are the wrong way around, the motor will run in reverse and will blow instead of s/uck.
The headlight can be wired either way around so if these connections are switched, it shouldn't matter. You have a 50/50 chance of getting it back the same way as it was originally and if there is any problem with the light, you can easily switch these wires over.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Kirby G4 Bagged Upright Vacuum
I need a wiring diagram for a rainbow d4c
Are you talking about the power switch. The new power switches have 4 wires sautered to the power switch, where the old ones have 6 wires that slip in and lock into the power switch.
The blue ones are for your power cord, and the black ones are for your vacuum motor, and your power nozzle plug.
Secure one motor wire and one power nozzle plug wire to one of the black wires out of the new switch, and secure the other two, to the other black one from the power switch. It does not matter which ones that you match together. Secure one of each of the power cord to the two blue wires from the power switch. It does not matter which one of them goes to each wire neither. It is AC so power goes both ways.
Use twist on wire nuts to secure the wires to each other, and put some electrical tape around each of them, after you secure them securly with the wire nuts.
It is best to secure the cluster of wires to each other with a pull tie, after you are finished wiring everything.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 25, 2010 | Rainbow Technologies D4 Bagless Vacuum
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Aug 31, 2008 | Miele S251i Plus Bagged Canister Vacuum
Vacuums Logo
178 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
