Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
How do i make my wireless router secure - D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
    President:
  • 548 Answers
Well you have to enter the router's address to configure the router.
Go to Network connections- right click on the Local Area Network icon- Status- Support- now look for the default gateway. That is the address of the router.
Insert that address (e.g. 192.168.1.1) and you will be asked for a username and password. Default it may be user: admin; password: admin; or blank spaces.
Now go to Wireless setup and chose Wireless Connection Setup Wizard. If you do not want the wizard you can always do it manually. Follow the steps provided by the wizard and you will have your connection secured in no time.
If you need further assistance or if you have further questions regarding this problem please leave a comment.
Cheers
Posted on Aug 26, 2010
The wireless network security settings on laptop do not match settings on router?
Hello.
- This error occurs when the wireless security that you set on the wireless laptop does not match the wireless security on the router.
  • If the wireless router's security setting is WPA but on the laptop you used WEP for the wireless security, that's when a mismatch occurs.
- What you can do to resolve the problem is to delete the wireless profile you created on the laptop. After that, let the laptop search for wireless connection available, select the correct wireless settings and it should connect.
--For example the operating system of your computer is Vista, in order to remove the wireless profile you created and reconnect to the wireless router, do the following instructions:- Go to Start>Control Panel>Network and Internet> Network and Sharing Center- Click on Manage Wireless Networks on the left panel. Delete the wireless profile then Search for available wireless networks again. Type the correct wireless security settings on your laptop
-- If you would like to know what wireless security has been setup on the router, connect the laptop or use a desktop which is wired to the router then access the router setup page by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter. Enter admin for the router user name and your password (or the default, password).
--After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the wireless security or you can setup wireless security from there if you haven't done so.
Hope this helps. Have a nice day. Don't forget to vote if you find this guide helpful. Thanks.
Nov 26, 2011 | NetGear WNR2000 Wireless Router
Wanna know how to secure my belkin wireless G router.
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed
Configure Wireless Security on Belkin Router - Enable WPA and WEP Why should we setup wireless Security on Belkin Wireless Router ?
After configuring your Belkin router you should secure your wireless network using proper wireless encryption. It can keep wireless hackers away from your wireless network and the unwanted sharing of your Internet connection. In order to know how to login and configure your Belkin wireless router click on the link below.
How to Setup Belkin Wireless Router
Setup Wireless Security in Belkin Wireless Router
Now I hope you just followed the steps mentioned in the above link and log in to your Belkin Wireless Router. In order to enable wireless security on your Belkin router click on Security Under wireless. ( Security tab present on the left side of Belkin configuration page).
You can select either WEP or WPA to secure your Belkin Wireless network. To know more about WPA and WEP click on the link below.
Which is better WEP or WPA on your Wireless network
Enable WEP in Belkin Wireless Router
To select WEP for your Belkin wireless network ,click on security mode drop menu and select WEP. WEP is of two kinds WEP 64 bit encryption and WEP 128 bit wireless encryption. You can type your PassPhrase and generate instant wireless key for your Belkin wireless network.
After generating the wireless key, you should save settings by click on Apply changes. Now onwards to login to your Belkin wireless network, you need this wireless key.
Enable WPA in Belkin Wireless Router
WPA is more secure than WEP. To enable WPA on your Belkin router, select WPA from security mode drop down menu.
You should enter a pre-shared key to enable WPA security on your Router. Don't forget to save this WPA settings.
Aug 28, 2011 | Computers & Internet
Where is the network security key
goto settings security ,now here enter the WEP key.
Feb 12, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G WRT54G Router
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
Jun 18, 2010 | Linksys WRT160N Wireless Router
Can't get access to my secure netgear router
If your computer does not connect to the wireless router, most likely the wireless card has not been configured with the router's wireless settings ie. SSID, encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 29, 2010 | NetGear WGR614 Wireless Router
Says not secure
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Dec 06, 2009 | Belkin (F5D9230-4) Wireless Router...
I DO NOT KNOW HOW TO SECURE MY MR814V2 ROUTER
Hello! To secure your wireless router, have a look at this Knowledge Base article below. This will guide you through the steps of how to set up wireless security on your exact model router.
MR814v2 Wireless Router Security Configuration Guide
Best of luck!
Mar 16, 2009 | NetGear MR814 Wireless Router
Wireless security
Just open the link below for the step by step procedure in setting wireless security on your router.
Setting up wireless security on a Belkin F5D7230 Wireless Router:
Dec 22, 2008 | Belkin (F5D7230-4) Router (587009)
Security
Go to the router's web interface (192.168.1.1), in the wireless section go to Wireless Security. Enable WEP, you will create a WEP key for your wireless network, then that key will be asked to any wireless device that tries to use your wireless network.
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
65 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
