Question about MSI MS-6702E Motherboard
What power supply do i use for my msi ms6702 motherboard
3 Suggested Answers
SOURCE: Problem with motherboard MSI P35 Neo2-FR
I just bought a msi p7n sli platinum. my board is better than yours hahaha, j/k, all playing aside, I have the same problem with the 8pin power connection. A power supply rated v2.2 has the proper 8 pin connection, but 2.1 or lower doesn't, regardless, plugging in two 4 atx pin connectors wont work because you'll be taking 4pins away from the main 24 pin plug (even though my manual says 20 pins will work, it doesnt, they lied!!!). However, when I put the normal configuration of 24 then the 4 in place of the 8, it works fine. The only thing i would worry about is overclocking, thats when you need to be careful with your voltages, etc. Also, I read somewhere that the 8 pin is actually 2 four pins, each 4 pin is for each side of the cpu...
Posted on Aug 13, 2008
leethedeuce
  • 4472 Answers
SOURCE: I have an MSI 785GTM-E45
First thing I would do is try a different power supply as those are relatively cheap. If the problem persists it is likely a CPU problem.
Thank you,
Lee
Posted on Aug 22, 2010
Msi Motherboard MS 7616 start up
check power supply and the front panel pins look for all plugs for power are in the right plugs
Dec 09, 2013 | MSI Computers & Internet
Power supply
Any 450 Watt SMPS power supply is ok. Zebronic or Mercury retails around Rs.450 to 500. No need of costlier power supply like Corsair etc.
May 05, 2013 | MSI Custom 845 Ultra-c Ver:1 Motherboard...
Can i buy a pwer button for motherboard msi 1076820474446
No search hits come up on MSI 1076820474446.
All you need is an ATX Power On switch, if the Power Supply is an ATX form factor,
http://www.directron.com/atxswitch.html
If the Power On switch does not connect to the motherboard, then it isn't an ATX power supply you are using.
The Power Supply is an AT style.
Has a built-in power switch.
Or I can also show you this,
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
Two main power cables plug into the motherboard. Power Supply has it's own power switch built-in.
A steel rod from the Power On button pushes against the switch.
1) http://en.wikipedia.org/wiki/Computer_power_supply
2) http://en.wikipedia.org/wiki/Switched-mode_power_supply
3) http://www.howstuffworks.com/power-supply.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 30, 2012 | Computers & Internet
No power supply going to the JPWI of MSI RS480M2-IL.what to do?
Have you plugged it in? It is used as a seperate power supply for the Processor. There will be a cable from the PSU with the correct connector and yellow and black leads going to it. There will be a 4 pin square connector on the end of it.
Mar 19, 2012 | MSI RS480M2-IL Motherboard
MSI 915GM-FR Motherboard monitor looses power turns off /standby mode
this problem i have seen mostly with the d845gvad2 (series) motherboard. i myself is using it and it often happens. unplug the power supply connector from the SMPS and plug it again tightly, also press the RAM tightly, the RAM Sloth may be loose. Keep in mind, do it with the main power supply unplugged....
Oct 09, 2008 | MSI 915GM-FR Motherboard
MSI MS-6702E Motherboard Logo
27 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
