Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman DLT 3000 with a Kohler 20 V-Power twin engine. Oil is leaking directly over exhaust which results in smoking. I'm not mechanicaly inclined. Oil appears to be coming from an aprox. 4" square block on right hand side. Any ideas.
2 Suggested Answers
SOURCE: i have a craftsman Dlt 3000 riding mower with a
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Posted on Aug 20, 2011
Isuzu 3000/Diesel/Turbo/Wizard, I can see a bit of Oil coming from Intake/ThroughBody direct to the Turbo & there also a White Smoke from the exhaust + Misfiring and the car is not pooling as uses to be......
Turbo shaft oil seal is probably leaking a little bit, though not ideal it isn't unusual and not particularly detrimental (mostly).
The white smoke indicates either a water or coolant ingress into the combustion chamber or an excess fuel condition. A small fuel excess usually results in a increasingly dark smoke, grey to sooty black and sometimes an increased diesel knock but large amounts of excess fuel results in white smoke which is unburned fuel.
This is often the result when the fuel injectors are sticking, dribbling, leaking and misfiring could also be a further symptom. Bad starting could be caused by several things needing attention but poor injector performance can be a major factor.
I suggest you have the injectors removed and tested.
Jul 18, 2017 | Isuzu Cars & Trucks
How do i fix a smoking Kohler 535cc engine?
if it is a mower motor then I suspect that the air filter is leaking dirty air into the cylinder and has dusted the motor
(worn rings from abrasion)
check that the oil level is not over full
it may require a ring job
Jul 09, 2015 | Garden
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
26hp kohler engine started smoking suddenly. still runs good.whaat would cause this problem.
Head gasket blown. This is a very common issue with these V twin Kohler engines. There is a kit you can order from Kohler that includes gaskets and new improved head bolts. Simple hand tools is all that is needed. You will need an inch pound torque wrench. Torque specs are included in the kit.
Jul 23, 2014 | Craftsman Garden
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman mower with 26hp kohler smokes when i cut on hill, why?
what happens is the oil gets into the valves which will come out the exhaust when on level ground after a side to side or going straight down because the valve's are in the front of engine which is pointing to the front of mower you wont hurt the engine if it does that i would just check the oil often to make sure it doesn't run out
Jun 13, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
111 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
