Question about Kenmore Elite Oasis 27052 Top Load Washer
Washer reading F1 - Kenmore Elite Oasis 27052 Top Load Washer
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What foes Error code f1 mean?
    Error Code Definition
    • According to Appliance Parts Quick, the error code is defined as a "Primary Control Failure." This means that the small computer installed in the washer has failed to send, receive or communicate with any other part of the washer.
    Reset the Code
    • To stop the flashing and beeps on the washer, hold down the "Start" and " Stop" buttons for 60 seconds. If this does not work, unplug the washer for 30 seconds and plug it back it or leave it unplugged since it is inoperable.
    Parts
    • The main problem is with the machine control assembly. This whole part needs to be replaced. Depending on your model, prices range from $150 to $260, as of 2011.
    Process
    • The installation of the new machine control assembly, requires manual installation and opening the washer itself. If you have never taken apart or repaired a washer, a professional should provide the service and care. Contact Whirlpool support for more information on repairs and warranty.
    Read more : http://www.ehow.com/info_7936847_whirlpool-washers-error-code-f1.html
    F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed. Unless you have both the skill and tools to test the guts of this computer, you're stuck replacing it. Good news, three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and receptacles. At wholesale, the part is $175.00. CODE 083009 part W10189966 CNTRL-ELEC
    Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
    http://forum.appliancepartspros.com http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
    Jun 19, 2015 | Kenmore Washing Machines
    My washer stops &and F-20 appears on viewer. Whats wrong with my washer
    water problem check screens in hoses and valves !! rrors F1, F11 and F20
    • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
    Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
    Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
    Starting the machine it buzzes and it read F1 what does this mean?
    F1 is a fatal error within the main control. You will need to replace the control. It is accessed by loosening the screws from the rear control panel.
    Kelly
    Mar 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 ERROR MESSAGE ON CABRIO. I STOP THEN START AND ALL IS OK. BUT, TO AVOID THIS, WHAT PART DO I NEED TO FIX THE PROBLEM, SOMEWHERE I READ SOMETHING ABOUT A PART IN THE LOWER REAR PORTION OF THE WASHER?
    Hi
    F1 error which is a common issue with Cabrio washers indicates primary control failure and manufacturer is aware of it. To resolve this issue I'll recommend you to contact Whirlpool at 800-253-1301 so that they can replace the parts without any charges. Please let me know if you need more help.
    Thanks Rylee
    Oct 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    The screen reads F1?
    Well error F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed.
    First of all you may leave unplugging the washer from the wall, leave it unplugged for a while. That may reset the internal computer chip. If further you have the same problem then it need some part (chip) replacement need some skills of electronics, part is $150 CODE 083009 part W10189966 CNTRL-ELEC. Post comments for further help or information...........
    Good Luck!!
    Thanks for using FixYa!!
    Oct 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 code mean
    A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
    Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
    Get appliance parts at http://parts.fixitnow.com
    Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
    My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
    There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
    Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
    Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore Elite Oasis 27052 Top Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
