Question about Whirlpool GH4155XP Microwave Oven
Microwave sparks then will not work. Could it be the fuse? It is a Whirlpool.
  • Whirlpool Master
  • 17,130 Answers
It is tthe magnetron having the spark sometimes due to an insulation leak in the fitting .
Please check the spot where the magnetronis fitted to the cabin. Inside of the cabin there is a insulation cover and if some food particles are stuck on it due to non usage of food cover, then it is possible that the conduction of the food on this is smoking or causing an insulation break. So clean and remount the magnetron if not change the unit if the estimation is reasonable.
Credit if the advice helps
Posted on Aug 25, 2010
I have a Whirlpool Microwave! It kept saying open/close door. Than everything went out! Nothing works! Is there a fuse or reset button?
Please post the model number of the microwave for more detailed assistance. Sounds like a fuse in the microwave shorted out. Most likely caused by a bad door switch. Recommend replacing all door switches that are there and then replace fuse.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 25, 2017 | Whirlpool Microwave Ovens
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
While changing light bulb, the bulb broke and sparked . This caused the breaker to trip. Since this acurred the Microwave has not worked. no power. I resset the breaker and tested the outlet it has power....
There is a fuse located inside the unit, that has probably blown. This is usually replaced by an appliance repairman - but if you are handy and can remember to kill the power BEFORE attempting replacement, you can save a few bucks.
Whirlpool has made a repair guide or "job aid" for their field service personnel, and it is quite detailed, and includes helpful pictures. Rather than paraphrase it - you can follow the link below and download it yourself. Page 4-6 details fuse access. The link:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eb51f29dbe5773c18525726e00793aa7/$FILE/Whpl%20BaseLineMHC.pdf
Copy and paste the text above in your browser's address box to download the job aid. it is _very_ important that you replace the fuse with the exact replacement. Deviating from the type, style, etc. can lead to fire or nuisance fuse failure.
Please rate this reply if it was helpful to you. Good luck!
Jul 09, 2010 | Whirlpool MH2175XS Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Our whirlpool microwave does not heat. Everything
Hi!if your microwave does not heat, it only means that the magnetron is not working, try to look for busted fuse. or check the capacitor for leak, the hi voltage diode sometimes malfunction, and if all of the above mentioned are all ok maybe your magnetron is defective.
Sep 15, 2009 | Whirlpool GH4155XP Microwave Oven
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Microwave
be very careful cos microwaves can kill - there is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
Mar 27, 2007 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
76 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
