Question about Microsoft Zune JS8-00001 Digital Media Player
Where do I buy teh tri wing phillips screwdriver needed to replace the battery?
    Brigadier General:
  • 5,158 Answers
Dollar store ... if you mean seperating the case just get a guitar pick. failing all that i've seen "kits" on ebay with all the tools you would need
Posted on Aug 25, 2010
How do i remove the battery on a macbook white
on a unibody you have to use a special tri wing screwdriver. ifixit.com sells them cheap. you need to remove back cover, 8 screws Phillips head, then you need to lift the battery connector from the logic board with a spudger available at ifixit.com or some other tool that is plastic.
ifixit.com has detailed instructions for free. no catch. taught me a great deal. on how to do anything to your macs. for free-no catch.
there are a couple of Phillips screws inside and three tri wing screws. the first two tri wing screws are visible and the third on is under a small plastic flap near the slot where you load disks.
May 23, 2014 | Apple iBook Mac Notebook
Touch screen is not responding and can not play any games.
Perform a recalibration as soon as you notice a problem, to prevent performance errors.
If the calibration problems do not go away you may need to contact Nintendo for technical service or if you think you can replace the screen you self i can give the process to do so...
How to Replace a Nintendo DSi Touch Screen
Finding someone to fix a Nintendo DSi touch screen can be time-consuming and costly. However, with the right tools, you can do it yourself. Even if you've never tried fixing anything until now.
Instructions
things you'll need:
* Tri-wing screwdriver
* Precision Phillips screwdriver
* Precision flathead screwdriver
* New Nintendo DSi touch screen
Turn the Nintendo DSi over and find the five screws on the edges of the bottom. Take each one out with your tri-wing screwdriver. In the center you will find an additional screw that will need to be removed with a precision Phillips screwdriver. This keeps your battery in place.
Take the battery out. Underneath it you will find two screws that must be removed with the tri-wing screwdriver. After both have been taken out, pull up on the bottom casing to access the motherboard. In order to replace a Nintendo DSi touch screen, this will have to be removed.
Detach the right and left buttons in the top corners by pulling up. Underneath each one will be a spring---make sure you don't lose these. Then remove the four screws in the middle of the motherboard with the precision Phillips screwdriver.
Look for the ribbon attached on the bottom left corner of the motherboard. Take a precision flathead screwdriver and pull up on the black bar that connects the ribbon. You should be able to slide it out by pulling back.
Find the two small connectors that are locked in with two tiny clips on each one. Lift up on all four clips to pull out the underlying connectors. Take out the motherboard and turn it upside down. Now you are ready to replace your DSi touch screen.
Detach the Nintendo DSi touch screen with your fingernails. Pull it away from the adhesive, one side at a time. Take the new screen and peel away the protective plastic before replacing it. Line it up where the old touch screen was and reassemble the Nintendo DSi.
Hope it helped...
Aug 15, 2011 | Nintendo DSi Blue Console
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
Unable to read the disc despite cleaning (brand new disc) and putting in correct way still unable to read
You need to replace your laser. Pretty easy and cheap lasers on ebay are around $10. Youll need a tri wing screw driver and small phillips head screwdriver.
Dec 26, 2010 | Nintendo Wii Console
Unable to read disc
If your console is unable to read disc, then there seem to be a problem with the console, and the problem most likely is as a result of a bad laser/lens inside the console.
To replace the lens of the nitendo wii console, remove the two flip up panela on the side of the wii to reveal the black face plate with the controller ports and memory card slot.
Then remove the three screws located underneath the flip up panels using the fine phillips head screwdriver, then remove the black face plate.
Then remove the two tri wing screws located underneath the face plate. There are also two phillip head screws under the face plate but you can leave them in place.
Use a scalpel to peel off the two white stickers that are covering the screws located near the two front rubber feet on the bottom of the wii. This will reveal two black tri wing screws.
Use the scalpel to remove the two back ribber feet on the bottom of the wii, this will reveal two silver tri wing screws. Remove the two black tri wing screws and the two silver tri wing screws revealed on the bottom of the wii.
Use the scalpel to remove the rubber foot that is covering a screw in the top left corner at the back of the wii. Remove the screw using the fine phillip head screwdriver. Then use the scalpel to remove the white sticker covering the screw directly below the bar code on the back of the wii. Remove the screw with the tri wings screwdriver. Then use the fine phillip head screwdriver to remove the screw that is holding the battery cover in place on the back of the wii. This will reveal another screw that you can remove with the tri wing screwdriver.
Remove the front face plate of the wii, be careful because it is still attached to the console by a black and red wire. Disconnect the wires by lightly pulling on it. Remove the wii shell casing by gently lifting the separating it from the internal electronics of the console.
Remove the DVD drive by taking out the four corner screws using the large phillip head screwdriver then lift up the DVD drive and disconnect both power cable and ribbon cabble connecting it to the console.
Turn the disassembled console upside down, remove the two screws holding the DVD citcuit board in place, disconnect the three ribbon cable that are attached to the DVD circuit board, Use the tweezers to free the wires that are still connected to the circuit board from the plastic clips, Lift up the DVD circuit board and remove it from the way, then remove the lens case that is holding the lens ribbon cable in place.
Use the tweezers to remove the lens casing by lifting up on one side hooks that are holding it in place. This will reveal the laser lens unit, Which is held in place by two metal bars. Take out one of the metal bars by first removing the screws located next to it, and then gently lifting up on the plastic tab so you can slide it out.
Remove the laser lens unit and turn it over to reveal a white plastic part held in by a screw. Take out the screw so you can remove the white plastic part. You will need the part to install the replacement lens.
Attach the white plastic part from your old lens to your new lens using the same screw from the old unit. Place the new lens in the console and reassemble The DVD circuit board.
Remove the two solder points located on the lens ribbon by using a hot soldering iron.
Then reverse the process to reassemble the console.
Take care and good luck.
Hope this was helpful
Dec 03, 2010 | Nintendo Wii Console
How do i fix the start button on my gameboy color? its sort of old but it work like last week. and now the start button just isnt working and i keep pressing, but nothing
The contacts are probably dirty. What you need to do is take your Game Boy Color apart and clean them. Unscrew the six tri-wing screws on the back (4 in plain sight, 2 behind the battery cover. Take off your batteries). If you don't have a tri-wing screwdriver a small enough flat-head one works fine, too. Take off the back plate of the GBC. There are three phillips screws holding the main board in. Remove those too. Carefully lift the board and turn it to the other side (don't try to remove or damage the ribbon connecting the screen). You will see the contacts for the buttons. Clean them with a soft (hopefully lint free) cloth. Sometimes scratching the grime through the cloth works. After you can see the contacts (4 for each button in the case of Start/Select) reassemble your Game Boy following the reverse steps. WebRepOverall ratingThis site has no rating(not enough votes)
Oct 07, 2010 | Nintendo Game Boy Color Console
Loose wing mirrow
Check this guide as reference for solve ypur problem; this is one DIY about replace Wing Mirror...
1.- Disconnect your negative battery cable, if your Ford Focus has power side mirrors. If it has manual side mirrors, disconnecting the battery is unnecessary.
2.- Pry off the wing mirror's inside sail panel (shaped like a triangle). Insert a trim panel tool between the door skin and the plastic panel to pry it off.
3.- Carefully pull the sail panel away, minding the wiring if the mirror is power-operated. Unplug the electrical harness and set the panel aside.
4.- Open the door and hold the outside part of the wing mirror steady. Remove the mounting bolt with a socket wrench, and then remove the mirror screw with a Phillips screwdriver (the mirror bolt and screw is visible with the panel removed).
5.- Pull the wing mirror assembly from its mount (from the outside). Insert the replacement mirror assembly in place; tighten the bolt and the screw.
6.- Attach the wiring connection to the replacement mirror. Position the sail panel in place and push it against the door to snap it back on.
Hope helps (remember comment and rated this). TY for using Fixya.
Jun 26, 2010 | 2000 Ford Focus
Tool to open fuji finepix j150w
where did you buy the replacement screen? I just broke mine :(
Sep 22, 2009 | Cameras
I have a Fuijifm Camera/finepix A345 with 4.1 Mega Pixel. The zoom lens is stuck in the closed position. When you turn the camera on, it states Zoom Error. The camera will still show the pictures on the...
Face the camera lens towards the floor and firmly tap on the back of it while tunring on, make sure you have new batteries or that the battery is fully charged, you may have to do this a number of times before it releases the zoom. Camera's require specialist tools to open them up, you may have to get it serviced
Dec 01, 2008 | Fuji Cameras
Need some help
usually to replace the tumbler(where you put the key) teh case around it should have like 2 to 4 scews in the bottom of the case usually phillips head......they will be in deep holes that you probably cant see the screw in it....stick a screwdriver in it n check....let me know what happens
Sep 18, 2008 | 1995 Chevrolet Camaro
Microsoft Zune JS8-00001 Digital Media Player Logo
49 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
