What is the function of the Line/Micro button on the back of the RCF ART 200A?
  • 3,866 Answers
Micro stands for microphone
Line stands for line in
So you can hook up a microphone or maybe a ipod/recordplayer/ ect ect
Did this answer help?
Please do rate it before you leave, thanks
Posted on Aug 25, 2010
  • 4,234 Answers
Just for clarity, Rulds was correct, but realize that there are 2 different sound sugnal levels. Microphone levels are lower than Line levels and require additional amplification stages. Line level is the typical output from tape players and CD players.
Dan
Posted on Aug 26, 2010
Micro sd card
I didn't know they made "real" 64 gigabyte micro SD. Get a 7 GB SD card and try again.They do make 12GB and 20GB micro SD cards but they are expensive.
Jul 05, 2016 | Audio Players & Recorders
How do I cut the power on a Bryant 200A load center?
there should be a quick disconnect where the line goes to the house by the unit, just pull the disconnect out of the box
Jan 08, 2016 | Bryant Electrical Supplies
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Rcf art 725
hi i got problem with my rcf725.amplifier problem.
Jul 01, 2013 | Audio Players & Recorders
Protect indicator is always on and motor boating sound
The amplifier is unable to achieve DC balance. This will require servicing. Could be a bad capcitor in the power supply.
Sep 04, 2011 | Rcf ART310A 10 Active Reference Speaker...
The Limit Prot LED on my RCF Art-321A speaker remains on upon power up. The speaker also pops upon powering down. What do you think it could be? Thanks
The amp is blown. Some popping on power down is NOT uncommon, but the protect LED means the pwer amp is out of balance which is ******* speakers. Take in for repair.
Aug 05, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
Need the part nmber for a rcf art 315 woofer 15"
The part number can probably be obtained from RCF directely as the speaker may be specially made for them. The specs are:
15" high power woofer, 64mm edge wound aluminium coil
email them to request part number at:
e-mail: rcf-usa@comcast.net
Apr 13, 2011 | ART 315-a Rcf Art 315a 2-way Proaudiostar
I have a Micro Innovations KB730/Kb740X key board. and scine I upgraded from Vista Ultimate to Windows 7 Ultimate, the extra buttons and scoller do not work. it functions as typing key board only. Is there...
Are you saying that everything worked under Vista? As far as I know this keyboard has not had an up to date driver since Windows 2000. When you do not run the driver the scroller and the top row of buttons will not work but the other features will work.
When you do run the old driver the scroller will work, the some of the top buttons can be assigned to other functions but some cannot. Also, when the driver is running the forward and back buttons only work for Internet Explorer.
Dec 20, 2010 | Micro Innovations Web Access Pro Keyboard
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
42 people viewed this question
 Grubhead
Grubhead
