Question about Dewalt DC900KL Heavy - Duty 36 - Volt Cordless 0.5" Hammerdrill/Drill/Driver Kit
36 volt drill chuck locked up will not open or close. Its closed to fit a 3/16" bit size. How do I free it to adjust again?? ET
  • 313 Answers
SOURCE: dc926 xrp hammer drill
ya its a chuck problem wont hold in reverse
Posted on Aug 12, 2008
  • 193 Answers
SOURCE: dewalt DW988 drill chuck
lock the drill in a vise so you can work on it. Then try working a very small screw driver tip into the jaws as you at the same time back up the jaws. They may be jamed against each other.
Posted on Nov 22, 2008
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
My dewalt d21008 drill is stuck in a smaller size bit opening . No bit in the chuck. It just will not open up??
hi
clump the drill in a good size vice then use 36" stilson spanner
adjustable adjust to fit the chuck then an do
Mar 08, 2017 | Dewalt Drills
My lithium 20 volt drill is not working. the chuck is will not open and close. you cannot move the front and back sections independently so you cannot tighten a drill bit. How can I loosen the two...
Hold the chuck and run the drill either forward or in reverse until the chuck is fully closed or open then reverse it while holding chuck.
Jan 06, 2015 | Drills
Milwaukee1/2 magnum hammer drill keyless chuck stuck closed
yes call 1-800-sawdust that's the Milwaukee factory number. They can tell you what the spindle and thread sizes are so you can order a keyed chuck. They should even be able to tell you what chuck they have that will fit it.
Jan 12, 2013 | Drills
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck broken
Just happened to me. Oil the chuck and let it sit and soak. Very gently, put the dril into a vice to secure it. With a pair of adjustable pliers (somthing that you can get a good grip with) attempt to work the chuck free. It works but just be gentle so you dont break anything
Nov 16, 2009 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC900KL Heavy - Duty 36 - Volt Cordless 0.5" Hammerdrill/Drill/Driver Kit Logo
120 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
