Question about Garden
Manual for black sheep kmart tent - Garden
I have had a tent donated to our agency. Where can I get directions for erecting and finding missing parts?
This tent was made by NorthPole, which has closed its parts department. Check this notice, which does list some places you might be able to get some parts.
I caution you that this was a department store tent, made to hit a price point, and sourcing a few parts might cost far more than the tent it worth.
Aug 05, 2015 | Northwest Territory Family Cabin 8-Person...
How do I take down First Up Dome Mackenzie peak tent
You unzip the top stand inside and push up the top mechanism instead of pulling down. Let the tent collapse and then pull the polls at their joints and fold. Wrap you arms around and give it a bear hug until you can put it on the ground and tie it up. It will fit into bag.
QUESTION FOR YOU.
Where can I get one. I have the rapid creek I bought from Kmart but can't find one now.
Hope this helps
Feb 10, 2015 | Sport & Outdoor - Others
Secret code for sheep bounce find the hidden black sheep
blacksheep, bluesheep, turnedpinkinthewash, feedmewords, popcorn.
Feb 19, 2014 | Computers & Internet
Assembly Manual
Nothing to assemble in this kit:
Product Description Universal tent assembly and repair tool kit
1 mallet with white rubber head
1 guy rope: 15 m , colour Grey/Black
1 guy rope tightener
6 adjustable fasteners for ropes: 3.8cm x 1.3cm x 0.4cm
4 round closed hook head, zinc plated steel stakes: 23cm x 3.9mm
4 standard zinc plated steel stakes: 27.5cm x 6.5mm
4 zinc plated steel stakes: 23cm x 2.0mm x 1mm
4 zinc plated steel stakes: 28cm x 2.0mm x 1mm
8 nylon/elastic rubber rings: 29cm x 0.4cm
2 self-adhesive pathces: 7.5cm x 0.55cm
Oct 30, 2013 | The Camping Equipment Company Universal...
Manual for a northwest territory portland dome tent 17' X 9'
I NEED POLES FOR THIS 17 FT X 9FT NORTHWEST TERRITORY PORTLAND DOME TENT SAYS IT SLEEPS 8 PEOPLE AND HEIGHT IS 70" IT SAYS NEXT TO THE UPC BAR CODE IT WAS MADE FOR KMART.
I CALLED KMART THEY SAID SEARS.COM HAS SOME REPLACEMENT KITS THAT WOULD WORK THERE IS LIKE 8 DIFFERENT KITS. COULD SOME ONE TELL ME WHAT KIT WILL WORK WITH THIS TENT. THANK YOU INADVANCE.TIM
Jun 01, 2012 | Sport & Outdoor - Others
I have an Outbound Sierra-1 tent with no instructions for putting it up, can you help?
Lay the tent out. Thread the black poles diagonally and the grey through the front. Insert a pin to one of the black poles and then work the tent to the other end. Then put the other pin in by gently bending the pole. Make sure the tent is smoothed out as you bend it. Then insert a pin to the other pole. Lift the tent up with the fully connected pole and then smooth the tent out over the other pole. Do the same operation with the grey pole. Tie the tent up in the middle to the black poles. Attach the 'flysheet'. Then peg out the guy ropes.
Jul 31, 2011 | Sierra Tent
My sleep sheep's manual option is not working. It stops in 23/45 minutes. How can I fix that?
In order to have the Sleep Sheep run without a timer, you have to set the switch in the middle (left is 23 minutes, right is 45 minutes).
Jan 26, 2011 | Cloud B Sleep Sheep Plush Sound Machine
Is there a way to override the automatic shutoff on the sleep sheep
Hi, the Sleep Sheep can be set for 23 minutes by moving the lever to the left, or 45 minutes by moving it to the right. If you don't want to use the shut-off feature, move the lever to the middle, and the sheep should stay on until you turn it off manually.
Jun 06, 2010 | Cloud B Sleep Sheep Plush Sound Machine
Coleman salt lake tent 9 man no instructions please help?
the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
May 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Baa ba black sheep
The problem with that tune is there are two versus.
Note: getting this out of my work que
Mar 17, 2009 | Samsung SGH-E900 Cellular Phone
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
