My laptop in side vga conector avlable i want conect laptop to tv so how to conect
    President:
  • 2,600 Answers
First make sure that all your video drivers are updated....if the TV is failrly new and you are running Windows 7, there won't be any issues. Vista maybe alright but XP may gives you headaches, but it still will work if the video drivers are up to date. Attach the VGA cable to the TV and then your laptop. In most cases the software will pickup on the TV and install it as a generic monitor but the newer operating systems will name it whatever brand TV it is. Now, right click on an empty area of the desktop and go to either "Properties" or "Graphics Properties", it depends on the operating system and graphics software. Now look for the "Display Settings" text. Look through the choices until you find the "multiple display" settings. Here you can choose whether to run the displays in a "cloned" manner or extend the display from the laptop to the tv, thus making one very wide display area, or you can flip the displays, so that the tv will be the primary and the laptop screen will be the extended area. etc. Once the display is showing up on the screen, you can also change it by using the "Fn" key in combination the an "F" key on the upper portion of the keyboard. These "F" or function keys are different on every laptop and maker but look for the button that has the icons of two monitors, this is the function key that will toggle through all the video choices available to you.
Posted on Aug 25, 2010
Just yesterday i buy 42 led lg tv 5400 how i can conect my tv to pc for run inernet normally
There are many ways to do this:
1) use the VGA inputs on the tv (assuming you have VGA output on the computer)
2) use the HDMI inputs on the tv - if your PC supports this with a connector on the PC side...
3) use the WHDI interface - which requires an adapter kit unless you are connecting a laptop with this function already built in.
Nice TV - good luck!
Dec 09, 2013 | Televison & Video
What cable do I need to conect my HP computer to my Element TV?
check computer and tv for same type of conection - VGA, DVI, HDMI
Oct 15, 2012 | HP Pavilion dv4-1028us 14.1" Widescreen...
How to add tv as external monitor
OK first MSSWIN1 there are a lot of missing info in your question. Does your tv has a vga conection if it does this is easy just conect the vga cable to the the computer and the tv and the computer will dectect the tv authomatically if you're running on windows if you wantto use the computer's screen (that is if its a laptop) and the tv at the sametime you will have to go in to the settings and change it. { control Pannel=Appearenceand Personalization=Display=connect to an external display. .. Somepc's will alow you tochose fromprimary to secodary monitor,
OK if your pc does not have any VGA connector you will need a VGA to RCA convertor dont buy the cable (VGA to RCA) those don't work you will still need to buy a conversion box
Sep 22, 2012 | HP ProBook 4430s Notebook
How do I connect my laptop to the TV with HDMI
You will need an adapter (VGA to HDMI) you will conect it as a second monitor, if your TV has a VGA connector you can just plug your laptop in directly. thundersecurityonline.com
Apr 28, 2012 | Computers & Internet
My PC has only VGA output and the LG monitor has DVI-D / VGA but the VGA connector seems to be damage. How can conect to the DVI-D conector in the monitor?
you can buy new vga connector, change the damaged with the new one, you can buy this part separately at computer shop at your town
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | LG Flatron L1919S LCD Monitor
VGA out conector unsolder
Good morning! Moigiver, you can unscrew the bolts at the back of your laptop to see the possible defect of VGA out Port & carefully solder it. However, I second the motion with WarheadsSE recommendation to seek assistance from a professional service technician to handle the task, to avoid future problems that may arise if not carefully handled. Best regards.
May 04, 2009 | Computers & Internet
How do i connect a tv to a compaq presario r3000 for ex video out
yo can use wich one you want, eiter VGA or Svideo ,for VGA you must have a special cable, if your tv is a lcd is ok you dont ned special conector just plug in normal cable betwin you laptop and the tv. to have sound on tv you need to get the sound from headset on you laptop. your video driver has to be the latest driver, from video driver property you can change the video on tv to use them at the same time.2 screen has to be set on lower rezolution to work at the same time.
Mar 06, 2009 | Compaq Evo N610C Notebook
How do i hook up a tv monitor to my campaq computer
usually laptops have vga conector for external display, you may need a cable, vga cable.
vga cable varies depends on the connection that you have on the tv, if your tv supports vga connectors thats great, some tv doesnt have that option, thats where adapters go in to adapt what ever ports or connections you have on your tv.
some of the cable adapters that you might need.
vga to hdmi.
vga to rca.
vga to dvi.
hope that helps.
Oct 17, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
