Question about Maytag MMC5000 Microwave Oven
Panasonic NN-CT776SBPQ, just 2 y old, burning smell advise what could be the problem and how much it cost\r\n
  • Maytag Master
  • 17,130 Answers
Check if the smell is coming from within the cabin. If so due to non usage of food covers some food particles ccould have got stuck while on heat to the sides of the cavity and results in heating and smoking. If so clean well with a dry clot and wipe out any moisture on the magnetron fitting slot.
However if the smell continues, check the capacitor to the magnetron or the magnetron or the main transformer itself.
You must open the cover and check for the origin of the smell.
estimate cost and decide.
Creddit if the advice helps.
Posted on Aug 25, 2010
Panasonic NN-A755
It does sound like the magnetron is failing, when it shuts down it is because the thermal fuse is detecting to much heat from the magnetron and shutting it down, I might add this part is the heart of the system, rough cost would be in the area of $100.00 maybe cheaper. Intallation of this part is very tricky and there is the danger of high voltage, I recommend a pro for safety and correct installation.
Apr 12, 2012 | Panasonic Microwave Ovens
My microwave nn-994s smell burning and is working 50% power panasonic model nn-994s
Due to the lethal voltages used and produced in inverter-based, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 19, 2009 | Panasonic Microwave Ovens
Whilst cooking strong smell of plasic & cabinet became too hot to
May be a shorted metal stirrer fan bearing located within the wave guide that feeds microwaves into the cooking area. If the oven is run without a proper load (water, or food), the voltage of the microwaves increase considerably causing things to arc-over inside the wave guide. You usually can't see the stirrer bearing short as it occurs internally.
Jul 23, 2009 | Panasonic NN-H765 Microwave Oven
My panasonic NN-S954WF smells when I start it.
if you are talking about the transformer then it will need replacing , because it is about to quit on you and then the microwave will not work at all
are you going to do the repair yourself? or are you going to need to take it to a qualified service shop?
Nov 27, 2008 | Panasonic NN-S954WF Microwave Oven
When I press the start button it smells like it is burning
if the is a convection model then the covection coill will smell that way if there is a geese build up and should be ok to use. however you should only smell that if you are using the convection mode.
Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
Jan 30, 2008 | Panasonic NN-S960WA Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Maytag MMC5000 Microwave Oven Logo
146 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
