Question about Archos 605 WiFi Digital Media Player
The remote 105715 for the DVR docking station dosn't not work
  • seosamh3905 May 05, 2008
    Is there a light on the remote when in use
On the back there's a tiny sticker that says 'Archos' and has the model number. Remove that sticker. Behind it is what appears to be a reset button. Use a straight pin and you should be back in business.
Posted on Dec 03, 2008
  • ericcabanac Jul 15, 2011
    Faux. Derriere cet adhesif, il n'y a pas de bouton de reset, mais seulement la trace du point d'injection de la matiere plastique lors du moulage du boitier... Et oui c'est aussi simple que cela.
I need remote code for sony xdr-ds12ip i pod docking station
call sony and request or check amazon. usually you can download an app for your iphone for remotes or you can try a universal remote. program it to your dock radio station
May 06, 2011 | Sony HD Radio and Dock Docking Station,...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Docking station
Vivitar was purchased by Sakar and they do not support anything that Vivitar used to make or carry any of the products. I suggest looking on ebay to see if anyone is auctioning it. If not, Google it for something like "Vivitar DVR 390H docking station".
But to be honest, it probably is not the docking station. I have had the same problem, as many others have had, that the connector in the camera is the issue. This camera has TONS of design flaws.
Jul 02, 2008 | Vivitar DVR-390H Digital Camera
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Wii docking station
try new (non chargeable) battery's and if they work then you have bad battery's, if they dont you have a problem with the remote or unit.
Jan 07, 2008 | Nintendo Wii Console
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
836 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
