Grundig tv Davio T51-3101 TOP. Horisontal pulse is missing.Regulator IC 61040 and 61050 in-voltage is ok, but out-voltage is only 1,3v.on both. Right value:61040, 7v. and 61050, 5v. IC 61060 is ok. Also CT 61043 and CT61053 seems to be ok. So what next?
  • 5 more comments
  • aarre_ilonen Aug 26, 2010
    Can you tell the position-number of the capacitors, like C50047. Have'nt find nothing wrong in any, but not changed none.
    Tks so far.
    Thanks for info, all that is ok, but first thing first, the 8 volt from regulator IC 61040 is missing, so there can not be voltage on oscillator. There is only 1,3 volt and that is the question, why. The same output voltage is also on regulator IC 61050. Input voltage on IC 61040 is higher than normal, about 19 volts,but thats, I think, is because there is no load on output. IC 61060 has correct voltages. Hpe this helps to go on.
    Thanks.
    Aarre
    Here I come again.
    As I sayed, there is no voltage E (8volt) on regulator out, and because it's directly coupled to horisontal driver, via transformer, so there is no pulse. The CT 61043 and 61053 are too tiny for me to handle, but on my opinion they are ok. Next question: What voltage should be on R61046/610456 from standby? In my case it's 4,5volts, too low?
    Thanks again.
    This is info on back of the tv-set:
    DAVIO 51- 3101 TOP
    VNM CUC 2103
  • aarre_ilonen Aug 27, 2010
    GRUNDIG
    CUC 2103/M
    DAVIO 51 T51 - 3101 TOP
    GCL 3302/VNM
    Well, problem isn't solved yet, but will continue to check further using your advice. Thank you.
    Sorry, but I've sent couple of times the type of tv, where do the messages go?
    Any way, I'll try to locate possible shortcut, so dont contact anymore. Thank you.
  • 12,061 Answers
You either have a Faulty Horizontal Oscillator IC? OR something, on that 1.3 V Output, is dragging that output down and on that output, something drawing too much current, and causing the IC, to not be able to drive to it's full potential, usually 5 V DC in a logic circuit, but if CMOS, then even 12 V DC.
All one can really do, is find the "Cause" of the low output, remove the "Fault" and/or change the IC, too (It's most likely damaged anyway? So I usually do)
You need to get the parameters of the IC & Semi's that you are working with and check the output against what it should be.
Also, you did not indicate if you were using a service manual. If not, then I implore you to obtain one, as without it, one really cannot work effectively.
As I always used to say to my students: Are Your Voltage Correct? Specifically, starting with the PSU, as if this isn't 100%, nothing else can be. Anyway check all voltages around your IC's & Semi's. Also remember the technique of "Cut & Test" too, isolating parts of the suspected circuits, by cutting a trace, or chopping a Leg or Pin, on a Semi or IC, can be useful in tracing where the fault is going. One other thing is Current Measurement, cutting into a circuit, and inserting the Ma meter, into the circuit, will also soon show you where the problem is, reduced current usually indicates a "Short", a high current usually show a disconnection, or "Open" circuit.
Hope this helps.
Posted on Aug 27, 2010
  • 5,138 Answers
CK power supply for Bad capacitors they will be vented,swollen or puffed up on Top 1000uf 16v 220uf 10v 3300uf 10v.
Posted on Aug 25, 2010
  • 1 more comment
  • ladywinn
    ladywinn Aug 26, 2010
    Normal Standby volt is 5, Google to this website and type in your model number see if they have Free Service Manual for this set Model# will be printed on back of TV
    Encompass Parts Distrbution 1-800-638-3328 I use this company all the Time and have printed out a number of service Manuals.Let me know what your model number is????
  • ladywinn
    ladywinn Aug 27, 2010
    I need to know Name Brand and Model number in order to help you.
  • ladywinn
    Hello ,
    Without the Service Manual I have no idea what board or locations of ANY Capacitors or what the the volts should be?? In the First place You still have not Posted your Brand Name of TV or the Model # therefore I have no way of knowing which board you are even talking about? Power Supply Board??
  • 5,807 Answers
• Check Horizontal Oscillator to Horizontal Drive.
Horizontal oscillator should have an standby voltage,
and another one when Flyback
oscillates.
• Check vertical Circuits for possible cold solder joints
here are additional guide :
a) basically it has to be acted upon by a supply voltage of at least 95V to work. sample picture
Source:
http://www.fixya.com/support/r3704932-a_basically_it_has_to_be_acted_upon_by_a
Posted on Aug 26, 2010
  • 21 more comments
  • Rommel Cana
    Rommel Cana Aug 26, 2010
    Additional guides:
  • Rommel Cana
    As per your request :
  • Rommel Cana
    Additional info for troubleshooting only, not for long use:
    • Extract the two ( transistors ) in yellow circle, just for the process of eliminating
    the cause of low voltage out.
    • The output should rise ( normally speaking )
  • Rommel Cana
    • Those two Regulators are Normally Off when the unit is plugged In to service outlet.
    Meaning having only a standby voltage or OFF
    • These would activate the circuits on the TV, If those above are checked ,
    And If OK your Flyback might oscillate , so be careful .
  • Rommel Cana
    • One reason , if transistors CT 61043 and CT61053 are OK, and still having a low output ,
    then there is a 5v drive on its base ( when those two ( 2 )
    • If the transistors are extracted and still having a low voltage out ,
    then it could possibly be the regulator itself or the LOAD of the Regulators
    like IC81500
  • Rommel Cana
    Horizontal Oscillator comes from here:
  • Rommel Cana
    •and here are the supply pins of the IC
  • Rommel Cana
  • Rommel Cana
    • or hang pins 12 ( + F )
    and pins 45 and 17 ( + E )
    of the Jungle IC
    • temporarily , just to determine that is the cause or not.
  • Rommel Cana
    Have you checked for voltages here:
    • If there is 5V on the blue arrow indicated both transistors will be ON,
    it will shut down the Output of the Short-Circuit Proof Adjustable Voltage Regulators
    LM317
  • Rommel Cana
    Rommel Cana Aug 27, 2010
    For your Question:
    " Next question: What voltage should be on R61046/610456 from standby?
    In my case it's 4,5volts, too low? "
    Answer,
    4.5V is near OK , ( if the unit is on standby mode ).
    These 4.5V will goes down to near 0 V when the Microprocessor turn your TV ON.
    Suggestion:
    a ) Remove the transistor ( CT61043 ) temporarily to find the cause
    b ) or just cut off the collector side that goes to pin 1 of IC LM317
    c ) Get an external power supply , even a 12V power supply will do.
    Unplugged the TV.
    Supply the + 12 V to the Regulator Input , It should show the true output of your
    IC 61040 and IC 61050
  • Rommel Cana
    • Your Circuit will look like these ( even when transistor is connected ) when using External supply
    not from your TV.
    Here is the Original Datasheet :
    LM317 - 3-Terminal Adjustable Regulator
    http://www.national.com/mpf/LM/LM317.htm...
    • You can view or you can download it for free
    But you will need a PDF reader to read it, if you downloaded it on your computer
    • like these one
    Adobe - Adobe Reader
    http://www.google.com.ph/search?q=get+ad...
    • Here is the schematics
    Full details on the web page or on the PDF copy
  • Rommel Cana
    • And your Horizontal Oscillator should run ( Normally speaking )
  • Rommel Cana
    Here is the snapshot on the page:
  • Rommel Cana
    Additional info , also from the PDF copy
    These regulator is very common to Regulated Power Supply
    Here are some other applications :
    http://www.instructables.com/id/LM317T-1...
  • Rommel Cana
    Another additional things to check:
    Near your
    Flyback
    there is a 7W resistor
    Have a check on it .
    • Check for open , check for possible cold solder joint
    • Check the horizontal output transistor ( T53001 ) , too
    and post
  • Rommel Cana
    • And here are the critical joints to check:
    ( to insure full operation )
  • Rommel Cana
    And here are additional guides for you to have :
    Troubleshooting
    Transistors
    On the number of 2 of the link above, describe how the transistor shuts
    down your regulator
    When there is a voltage applied on its base , it will turn ON ( acts as a switch , shorting the
    Collector and emitter pins ) Normally speaking.
  • Rommel Cana
    • Even a small converter or power supply will do ,
    Inject a supply on the input of the Regulator and measure the output.
    You can try these troubleshooting and have no fear that TV will turn ON.
    • An external supply of 12V can not fully turn On your TV, and you can safely check the load
    afterwards.
    •Just pretend you are assembling a regulated power supply with no automatic cut-off.
    Your Unregulated Converter will be connected to the TV Regulators for troubleshooting.
    • In these case , there will be no supply on the base of the transistors ( 0 V ) and the Regulator
    can work freely. ( without extracting the blocking transistor )
    Have you downloaded the pdf file? for LM317?
  • Rommel Cana
    Rommel Cana Aug 28, 2010
    I just hope my solutions are very clear to you, If you have any clarifications on the solutions
    I have presented please post back to help you further.
    Have you downloaded the design for LM317 from the Manufacturer?
  • Rommel Cana
    • A Safer Shortcut Way is to connect an External Supply 12V on the
    positive side of the Diode D61056
    here is the schematics to further help you:
  • Rommel Cana
    • It will not run , if you will not connect the negative too.
    have a note on the polarity of the power supply,
    • You can connect negative ( external power supply ) on the negative side of the
    capacitor C61057 or to the CRT ground strap or to the tuner chassis ground
    ( not from the ant input )
    Like one of these ( sample only )
  • Rommel Cana
    Rommel Cana Aug 29, 2010
    Thanks for rejecting assistance:
    • Even with an external power supply there might be still voltages that may cut off the supply
    of your regulator.
    Not unless you will cut off the 5V out or 5V Input ( regulator )
    • But these steps are safer than working with higher voltages , that may cause injury when
    troubleshooting ( when flyback oscillate ).
    • In these case also you will probably notice how the TV system works, without the
    high voltage running.
    thanks you been very kind.
    • Most often I use an adjustable home made regulated power supply ( with meter )
    before I check on the Deflection Circuits to check for Hor.Osc Circuits if it is running.
    here is a link for your service manual
    Grundig #65 Service manuals,repair manuals,schematic diagram
    http://www.sdvis.com/manuals/detail-7711...
    only with a fee
    Good luck on your troubleshooting!
How can i unlock child's lock on my grundig davio tv 14inches
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 04, 2015 | Grundig Televison & Video
Tv wont turn on
Hi
Normally Grundig tv sets when stop working the standby light is on. If it is so the power supply is faulty. You should check DC supply voltage in pin 6 of SMPS IC TDA4605.. If no voltage in this pin, check the limiting resistor connected in series. If these parts are OK, check the supply line rectifier diode for short.
Sully
Sep 20, 2013 | Grundig GF70-600 TV
Cod for TV Grundig DAVIO 55
Hello
Try these codes:
046/ 053
0051 0053
Feb 07, 2012 | Televison & Video
Tv turns on ok,first displays black screen with 2 horisontal lines and some static at the top,than slowly from the top down i can see picture,after 5 min i can wacht tv but i have 2 lines -horisontal and...
Hi Marcin,
First of all, thank you for posting your question here at Fixya.
To diagnose accurately the exact caused of the symptoms, please let me know the Brand and model/chassis number of your unit. It is printed at the rear panel, manual and on the receipt. It will help to narrow down the symptoms and locate the availability of parts online.
Jdvillanueva
Jan 20, 2012 | Televison & Video
Retuning not holding memory
Hello
The memory IC in the circuit of your Grundig is not working. There are two resons for this fault. The first one is, of loss of voltage to that IC. This IC is a non-volatile type [that is, even though the supplied voltage goes OFF, the memory cells inside it will hold the last position memory, will not loss it]. This is a very samll IC, of 8 solder termiminals and can be located very near to the main system control IC. It is drived and memorized by main system control IC, by Serial Data, Serial Clock signals. Fault to this IC is quite normal to most of the TV, irrespective of brand and model number. It is very cheap to buy too, and can be bought from most of the electronic sparepart selling shops at your town. It has a number printed on it, must be noted before buying a new one. In some models of Grundig Tv, this IC will be an SMD [Surcace Mount Device] type. In others, it will be of norma DIN [Dual In Line] type. If the IC soldered to your tV is of fromer type, it cannot be replaced by normal soldering techniques. If it is of second type, it can be desoldered out and can be replaced with a new one. Look whether the type fitted to your TV's circuit is of second type [DIL]. If so you can do the work by yourself at home, provided you must ahve a concept of desoldering and soldering; a good quality DC soldering Iron, and an antistatic desoldering pump, and a very good quality digital multimeter, like Fluke or so. If the type is SMD, no other way other than get this set repaired by any well equipped service center of by the Authorised Service Center for Grundig at your town.
Check the board and confirm the type. Use of a hand glove is recomended when repairing this system control section, as the main system IC is very static to external voltages; even the voltage generated at the tip of human fingers may damage them. There is no other fault with your set, except this IC. The component is cheap to buy, but I don't have an idea about the service charge at your country.
If you haven't enough knoledge and skill to do the work, just get this set repaired by it Authorised Service center.
If you want anymore assistance from me, feel free to get me by Fixya. OK.
Sep 26, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
I have a sony trinitron puchased 2001 after 911 standby light flashes constantly picture flashes off and on
Hello
Complete loss of horizontal oscillation and output is the trouble. To get it repaired you have to open your TV, Just look the horizontal driver transformer, a small transformer fitted on the main board very near to the line output transformer [LOT] for winding opened. If its primary winding gets opend, even though the horizontal oscillator section works, the pulses will not reach the horizontal output trnasistor, which drive the above said LOT, and the fault you describes will occur. Check the main secondary regulated supply voltage [140VDC] also. If this voltage is missing, check the reason and follo the supply rail print from the SMPS power supply reguator section.
Check the low voltage regulator IC, usually 7808 or 7812, which can be located on the main board, which supplies 8VDC or 12VDC to the ICs on the main board. Anyway, there is no horizontal output fuction in your tV. and try to find it. If you wants furthermore assistance, feel free to get me through Fixya. OK.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv shuts off after screen goes red
Good Day sir, the reason why your tv act that way is the switching power supply. The power supply regulator, cannot supply the current needed by your TV. these can be caused by several factors. a faulty switching regulator, low power, or filter capacitor leaking, check the voltage across the VCC after the regulator, if possible the switching transistor. and the ic that controls the pulse they are usually near each other. for safety reasons, better consult your service personnel. hope this helps. if you need more assistance, do let me know. thanks
Jul 28, 2009 | Televison & Video
Repair grundig 960
CONTACT BROADWAY TV SERVICE THEY FIX MINE FOR
LOW COST:$25.00 FOR ESTIMATE APLIED TO REPAIR PLUS H&S(APROX TOTAL ON MY REPAIR WAS $95).
BROADWAY TV SERVICE
potterstvcr@sbcglobal.net
685 BRODWAY AVE
SEASIDE CA 93955
(831)394-2349
Dec 05, 2007 | Grundig Classic 960 Shelf System
STRS6707 problem
In the past, my experience with Sonys is that you need to use Sony parts to successfully repair them. Also you might have a cold solder joint which creates an arc when you turn it on. This arc will cause a "spike" which could possibly take out the regulator. Stargazer
Jan 15, 2007 | Sharp 32F540 32" TV
Televison & Video Logo
759 people viewed this question
Top Televison & Video Experts
