Question about Lexmark X8350 All-In-One InkJet Printer
Scanner The scanner won't scan. It will preview, but won't send the image to the computer. When the all-in-one center is open, and the scan button is pressed, it won't work, yet will print out a page just fine.
  • Ace1930 May 05, 2008
    Actually, I contacted Lexmark and got the problem fixed. Turns out, the firewall was blocking it for some reason, and all I had to do was configure it to allow the all-in-one center and the other programs. posting this up here in case others have the same problems. =]
Try scanning from the image software you are using, not from the front panel buttons. Go to the TWAIN options and make sure your scanner is selected, then go to Acquire and the scanner software will start. Scan from there without using the scanner front panel.
Posted on May 05, 2008
Could you help me to operate the scanner., so that I can send docs,
make sure your scanner is working properly and the software has been already installed to the server or computer to access the scanner. this steps can help you to operate the scanner.1. connect the scanner to your PC, mostly scanner now is using USB cable 2. and then turn ON your scanner, place your material to be scanned like you were using photo copier the scan button to acquire the image 4. then preview the scan, the scanner software should display a preview on your computer screen 5. and now select the scan area in the scanner software set other options for example set the the color or the resolution of the document 7. then scan the image and save it into your disk make as your new folder. after you save you can now send this document.
Apr 15, 2011 | Office Equipment & Supplies
How to scan a picture?
1. were you able to install the printer software correctly? if yes, please check the epson software in the program files if there a scan/imaging applicatoin installed.
2. if you have adobe photoshop. click import then select your scanner device. it will popo out the scanner software..
Jun 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    How can I save a scan to my computer? I just got a printer/scanner and there are no Save, or Save As options in the HP scan software?? Help!!!
    I would like to know the following, please get back to me
    * HP Printer model
    * Operating System
    * Is the HP Software installed..
    as a work around you can perform the steps below to save a scan in the computer.
    Try to scan using one of the two methods below:
    1. Scanning from Microsoft Paint:
    Click Start, click All Programs, click Accessories, and then click Paint.
    Click File and then click From Scanner or Camera.
    If this option is not available, Please let me know.
    If more than one image source is connected, select the
    HP all-in-one product and click Next. The scanning software will appear.
    Preview the image by selecting Preview, or click "Scan" to scan the image directly into Paint.
    The image will open in paint for editing and/or saving.
    2. Using Windows Image Acquisition (WIA)
    Verify that the all-in-one product power is turned on and the printer cable is properly connected.
    Click Start.
    Click Control panel.
    Click Scanner and Camera Wizard.
    Follow the Scanner and Camera Wizard instructions to scan images to the computer.
    May 20, 2010 | HP Office Equipment & Supplies
    How do you scan a picture into the computer with a lexmark P6250?
    SORRY, I COULD DO ALL, SAID TOO BIG, Using a computer 1. Make sure your All-In-One is connected to a computer.
    2. Load your document face down on the scanner glass. For help, see Loading your document on the scanner glass.
    Open the Lexmark Imaging Studio. For help, see Using the Lexmark Imaging Studio
    4. Click the Scan button.
    The All-In-One Center appears with the Scanning & Copying tab expanded
    5. Click Preview Now in the upper right corner of the All-In-One Center.
    An image of the scanned item appears in the preview section.
    6. Click and drag the dotted line box to select a specific area of the preview image to scan.
    7. Click Display Advanced Scan Settings to review and change the scan settings. Click OK.
    here is the web site where the info was. If you want to see better images just click on link below. good luck :0)
    Nov 19, 2009 | Lexmark P6250 All-In-One InkJet Photo...
    How to scan with mac
      1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
      2. Install any necessary software drivers that came with the scanner.
      Note: Not all scanners require the installation of additional software drivers.
      3. Turn on the scanner.
      4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
      5. Select the area of the image you want to scan.
      Figure 1 Preview image with area to be scanned selected
      6. Click Options in the toolbar to adjust settings specific to your scanner.
      Figure 2 Options icon
      7. Adjust any settings in the drawer that appears.
      8. Click Scan.
    The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
    Note: These are the default options. They can be changed in the Image Capture toolbar.
    Jul 16, 2009 | HP Photosmart C6280 Printer
    The following steps show you how to scan and save images.
    1 Open the top cover of the All-In-One.
    2 Place the item you want to scan facedown on the glass. Make sure the
    upper left corner of the front of the item aligns with the arrow
    3 Close the top cover.
    4 Open the Lexmark All-In-One Center
    The All-In-One Main Page appears.
    5 Click Preview Now located in the upper right corner of the All-In-One Main
    6 Click and drag to select a specific area of the preview image to scan.
    7 Click See More Scan Settings to review and change the scan settings.
    8 Select your scan settings.
    From the “Send scanned image to” drop-down menu, select a program to
    send the scanned image to, or click the Creative Tasks section to display a
    list of projects.
    Oct 13, 2008 | Lexmark X1240 All-In-One InkJet Printer
    Load the text document face down on the scanner glass.
    Click the Scan & Edit Text (OCR) button (shown below).
    The All-In-One Center appears with the Scanning & Copying tab expanded.Click Preview Now in the upper right corner of the All-In-One Center. An image of the scanned document appears in the preview section.
    Click and drag the box with the dotted lines to select a specific area of the preview image to scan.From the Select your text editor: drop-down menu, select a word-processing or text-editing program.Click Send Now.
    Jun 18, 2008 | Lexmark All-in-One Printer with PictBridge
    Sleepy Scanner?
    try using windows driver first, so that we will knowif there is a problem with your scanners driver.
    Open paint and click on file and click on from scanners and camera and let me know if it will give you an option to scan from that app or if you will get an error message.
    Apr 02, 2008 | Epson STYLUS CX5900 Printer
    Scanner, scans and then re-scans.
    you can go direct open my computer then you will find in the my computer window icon for HP officejet 4300 if you press it you can go ahead with wizard that let you scan your photo or document fast you can even send short cut to this icon at the desktop so you can reach it faster
     OR   ~~~~~~  another solution
    when you open the hp software press the scan botton then will open another window has two option choos scan and then choos scan again in the other window
    Please rate me if this solution was ok thank you
    Oct 15, 2007 | HP PSC 1315 All-In-One InkJet Printer
    Lexmark X8350 All-In-One InkJet Printer Logo
    173 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
