Question about GE Spacemaker JVM1640SJ Microwave Oven
The timer works, but food doesn't heat. - GE Spacemaker JVM1640SJ Microwave Oven
  • GE Master
  • 17,130 Answers
If the timer works then it is possible that the magnetron is faulty provided the high volatge flows in thrrough the mains transformer and the coupled capacitor.
If the magnetron seems good , then check the transformer and the capacitor.If suspect change and proceed.
Please check the fuse to this unit and also if the relay engages the power to the magnetron. If not check the relay drive and replace the drive transistor if faulty.
Credit if the advice helps.
Posted on Aug 25, 2010
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
The oven doesn't work, the timer works and the light comes on
This is a strong indicator the magnetron has failed "heats food" and is the heart of the system. If microwave oven is a few years old better to invest in new.
Mar 06, 2012 | Cuisinart Microwave Ovens
Microwave Model (1992) J KP6460P1B6 Doesn't heat food. Timer, clock, etc. work fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Aug 25, 2011 | Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
