Question about Refrigerators
I have an oster wine cooler model #owo912H6H that was not cooling i took the back off and have a blinking red and green light and a fan that would **** and run a few turns and stop i cleaned the fan and it started running but fan does not seam to be up to the speed it should be but is now running it cooled off a couple of degrees but not more is this worth trying to repair and do you have any ideas about the problem thanks
  • rcabels Aug 25, 2010
    is this a fan i can replace with a computer fan or do i need to go to a electronic supply store
  • 10,515 Answers
It seems this is either due to faulty fan or fan motor. This could be a reason that the wine cooler is not cooling at optimum rate. As i cannot see the cooler, this is what i could judge from the information you gave to me.
I would still say, it would be worth repair, if this is due to faulty fan or motor ( motor seems to be the main cause ).
The main tough thing would be to get fan motor. You could try to get a replacement motor or a compatible one from the parts store near your home and give a shot. More likely, you would be successful, if the fault is related to motor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 25, 2010
  • 4 more comments
  • taran_2005
    taran_2005 Aug 25, 2010
    Thanks for your response!!
    It has to be a different fan.You need to mention the model number.However, i doubt fan motor which is available for around 20 bucks ( for most of the models i am aware of ).
    Hope i helped you.
    i replaced the fan and it seams to run at the same speed as the one i replaced and ther is still no cooling, the lights are still flashing, i found a fuse but have not checked its continunity yet the interior lights and thermostat lights also turn on so i dont know about the fuse . what else could be the problem.
  • taran_2005
    taran_2005 Aug 26, 2010
    Check the continuity for that fuse. Also, check the fan motor.As i mentioned i would doubt fan motor.Kindly read :-
    Hope i helped you.
  • rcabels Aug 26, 2010
    the fuse seems to be okay it is hard wired to the board and has continuity. could the fuse still be bad? or do you have another suggestion?
  • taran_2005
    If the fuse does show continuity, they are fine. Check the fan motor and revert.
    Hope i helped you.
    It's a new fan and motor.
    Problem Solver:
  • 3 Answers
Posted on Aug 26, 2010
    Problem Solver:
  • 3 Answers
The fuse seems to be okay it is hard wired to the board and has continuity. could the fuse still be bad? or do you have another suggestion?
    Problem Solver:
  • 3 Answers
I replaced the fan and it seams to run at the same speed as the one i replaced and ther is still no cooling, the lights are still flashing, i found a fuse but have not checked its continunity yet the interior lights and thermostat lights also turn on so i dont know about the fuse . what else could be the problem.
2 Suggested Answers
  • 10865 Answers
SOURCE: Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
Posted on May 21, 2009
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Jun 25, 2008 | Refrigerators
Refrigerators Logo
234 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
