Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
The fax machine says "Fax Reserved" followed by a #. It will not allow me to send a fax. What does this mean and how do we fix it.
  • 1,110 Answers
Turn off the main power, then hold down the Clear/Stop button and continue holding down for a few seconds after turning the power back on. This is the procedure for clearing anything that is stuck in memory and will not process which happens sometimes on these Brother machines.
Good Luck and Thank You for using Fixya.
Posted on Aug 25, 2010
How does I fax something from my Canon MX320?
Follow these steps :
Prepare the document that you want to fax.
Prepare a fax cover sheet, if desired.
Open your fax software - such as Microsoft Fax or Microsoft Exchange.
Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5
Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6
Indicate whether you wish to send a cover sheet.
7
When asked to attach the file, follow instructions to attach the file that you want to fax.
8
When ready, click Send. The fax will begin to compile the information and, when ready,
9
When the connection is made, the fax will be sent.
Oct 26, 2010 | Canon Office Equipment & Supplies
Teach me how to operate a fax machine and what are the part of a fax machine.
HI there,
Well it depends on your fax machine. If its a new version type, you should be able to simply put in the pages to be faxed, and dial the number and it sends it - and if its a long fax, then you can just leave once the fax machine starts to operate. New faxes also allow your to send and receive color faxes, rather than just black and white - pretty sweet. If its an old one, you will probably have to wait for a dial tone. When it makes a ring sound, manually start the transmission, etc, etc. Also, if people send you a fax its also very hard because they will have to do it manually too (even if they're using a new fax machine model). If you like to know more about then please follow the below link -
http://communication.howstuffworks.com/fax-machine4.htm
Please provide us the model number of your Fax Machine if you need more help or information.........
Good Luck!!
Thanks
Feb 18, 2010 | Panasonic Office Equipment & Supplies
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
What does fax reserved #53 mean
Fax number 53 never went through. Watch your machine, when it starts to REDIAL press STOP
Jun 26, 2009 | Brother IntelliFAX 2800 Laser Fax
Our HP Officejet 5600 won't receive faxes.
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax Will not send or receive.
Unplug the power cord for 10 seconds.
It is not detecting a dial-tone.
Jan 30, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax Reserved
try unpluging the machine and the replug and let the machine reboot. brother tech
Jan 07, 2009 | Brother MFC-8440 All-In-One Laser Printer
How to send fax from computer ?
Please follw the below steps:
To Fax From Your Word Processing Program1. Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software.
2. Open the document that you want to fax.
3. From the File menu, select Print. The Print window opens.
4. Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print.
5. You will be asked to provide the recipient's fax number and other assorted information as with a fax program.
6. The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
To Send a Fax From Fax Software1. Prepare the document that you want to fax.
2. Prepare a fax cover sheet, if desired.
3. Open your fax software - such as Microsoft Fax or Microsoft Exchangemag-glass_10x10.gif.
4. Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5. Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6. Indicate whether you wish to send a cover sheet.
7. When asked to attach the file, follow instructions to attach the file that you want to fax.
8. When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine.
9. When the connection is made, the fax will be sent.
Thank you.....
Dec 08, 2008 | Office Equipment & Supplies
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Aug 26, 2008 | Computers & Internet
Dell 962 printer
Remote fax error means there is something wrong on the receiving end, not with your fax.
It could be that it can't negotiate the handshake with your machine (that static noise it makes when it first connects).
Or it's not set to a receive mode.
Have you tried just calling the remote fax with your phone to see if you can hear that it is in a recieve mode (you'll get the static) or that it's not going to an answering machine by mistake (a common problem)
Aug 01, 2008 | Dell 962 Photo All-In-One InkJet Printer
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
1,535 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
