Question about Dishwashers
The program indicator light is on constant, but will not change programs when pressing the program selection button. And when you close the door to start the cycle nothing happens
    Brigadier General:
  • 3,513 Answers
Hi
Please check the link regarding your query…
http://www.repairclinic.com/Dishwasher-Troubleshooting#Itdoesntworkatall
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 25, 2010
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Need instructions
The owner's manual will tell you step by step how to program it. Normally you would follow these steps (with the engine off):
1. Press and hold down the two outsid buttons releasing only when the indicator light begins to flash.
2. Position the end of your hand-held transmitter about 1 to 3 inches away from the buttons while keeping the indicator light in view.
3. Simutaneiously press and hold both the desired button and teh hand-held transmitter button. Do not release the buttons until the indicator light flashes slowly at first and then rapidly. Then releas both buttons.
4. Press and hold the newly-trained button and observe the indicator light. If the indcator light stays on constantly, programming is complete and your garage door should activate when you press the button.
Nov 26, 2013 | Wright Products International VC333BL...
Program garage door to my garage opener in my 2002 yukon Denali
Apr 06, 2013 | Building Materials
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Reprogram control board after replacement/ MFI2266AEU B/M REFRIGERATOR, M'TAG
Press and Hold Door Alarm Keypad
Press and Hold temp down keypad
Relaease door alarm Keypad and wait 3 seconds.
The control will display PE to indicate Programming mode.
Entry to programming mode confirmed by pressing FREEZER temp down keypad once more
The control will display the Current unit Programming Control code This code must be validated by comparing it to the Programming code stamped on the unit data plate (Model number plate)
If the programming code is correct all you have to do is close the refrigerator doors
To change the CODE press the REFRIGERATOR up or down keypad to change the digits.
To move between digits press the FREEZER up or down button. Decimal point indicates selection
Once the desired code is entered PRESS and HOLD the freezer temp down button until the CODE entered starts flashing.
Close the refrigerator doors or wait 4 minutes without Kaypad input for programming mode to exit.
That should be what you needed.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Maytag MFI2266AE Side by Side Bottom...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Reprogram garage door opener
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Apr 30, 2009 | 1997 Lincoln Town Car
How to set up for 2005 pacifica garage door opener
how about a real answer......
1. Press and hold the two outer HomeLink buttons, and
release only when the indicator light begins to flash (after
20 seconds). Do not hold the buttons for longer than 30
seconds and do not repeat step one to program a second
and/or third hand-held transmitter to the remaining two
HomeLink buttons.
2. Position the end of your hand-held transmitter 1-3
inches (3-8 cm) away from the HomeLink buttons while
3. Simultaneously press and hold both the HomeLink
button that you want to train and the hand-held transmitter
buttons. Do not release the buttons until step 4
has been completed.
4. The HomeLink indicator light will flash slowly and
then rapidly after HomeLink successfully receives the
frequency signal from the hand-held transmitter. Release
both buttons after the indicator light changes from the
slow to the rapid flash.
5. Press and hold the just trained HomeLink button and
observe the indicator light. If the indicator light stays on
and your device
should activate when the HomeLink button is pressed
and released.
Dec 11, 2008 | 2005 Chrysler Pacifica
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
