Question about Dell Optiplex GX280 (99301) Motherboard
Psu sounds like plane taking off - Dell Optiplex GX280 (99301) Motherboard
    Guru:
  • 302 Answers
Seems pretty much like you need to replace the fan on your PSU. :)
Posted on Aug 25, 2010
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
How to adjust
Those are funny little planes - they're wicked handy when you need one. I like mine a LOT.
They ARE coarsely built, not a "fine" tool, but they do a fine job.
Loosen the little screw SLIGHTLY, then either bump the rear of the iron (to extend it more) or the rear of the plane (to extend the iron less) against a piece of softwood (bench, sawhorse, 2x4, hammer handle). When it's where you want it, tighten the little screw again.
Adjust the plane's mouth (assuming that you're using it as a bullnose plane, not as a chisel plane) by loosening the big screw, then just sliding the bullnose front & rear.
Remember - planes are meant to SHAVE wood. The iron should NOT take off a thick shaving, it should take off a shaving no thicker than one sheet of toilet paper. The iron should BARELY peek out from under the plane.
Jan 14, 2014 | Stanley 12 - 975 Contractor Grade Bull...
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
I have an LG 32" LCD TV, following are its details: Model: 32LC4R-TA Chassis: LP78A/PP78A I have been facing issues with it lately. On inspecting, I found that the following chip is overheating ...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 10, 2017 | LG L4200A 42 in. HD-Ready LCD Television
How thin can i plane wood im planing to go to 1/16 inch
Use a backing board, such as high grade 3/4 inch plywood under the board you are planing, and you should be able to get down to 1/16, depending on the stability of the board you are planing. Take light cuts and flip it over to cut on both sides. Sounds like you might be making a guitar? Good luck.
Aug 16, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
I have a Toshiba TV/Combo The set will turn on then it turns of in a second. It will not stay on.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jul 14, 2010 | Toshiba Televison & Video
How do I plane the edge, end and surface of a board? how do i find a hand saw for ripping a board?
Are your arms big? Good, cause that is how you do it. With a lot of muscle. They have too many power tools out there now to make it easier. But if you want to do it the old way, you will need a handful of planes, not just one block plane. You need a couple of jack planes, smoothing plane, and scraper plane, to get a nice surface, the jack plane, 12 -14 inches long will go right over the bumps and flatten those edges right out, Keep it square to the edge. Look by eye and use a square to check. Your end grain can be done with your block plane, get it in a vise and take little cuts. Your surface is the tough one, it takes a sharp iron and a steady hand to surface a board, some woods don't like being surfaced, some do. Again, start out with the scrub plane, 8-12 inches, and run it against the grain to smooth, then the jack plane with the grain to flatten, then the scraper to finish. Rip saws are hard to come by, the teeth are at a 90 degrees to the saw. and wide, and you need big arms. The japanese saws have both edges on their saws and they work great. But you can't beat an electric planer. Hope this helps.
Apr 06, 2010 | Craftsman 7 in. Plane Block
4 second shutoff
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem. Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
Jan 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Loud humming sound when driving Chevy Malibu
sounds like a wheel hub bearing. Does it feel/sound like it's coming from the front of the car, or the rear?
Jun 29, 2009 | Hyundai Motor 1996 Elantra
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
