Question about Canon PC1061 Copier
How do you connect a pc1061 to a computer? - Canon PC1061 Copier
  • 1,110 Answers
The PC1061 does not have the option to connect it to a PC for printing. It is basically an analog machine.
Posted on Aug 25, 2010
Paper jammed in fixing assembly and technician says fuser assembly is $800.00
Is that for the gold plated version?
http://www.precisionroller.com/search.php?q=pc1061+fuser
Here is one for $179.95 and I suspect you might find them cheaper. I use PR all the time and they have free shipping.
Good Luck.
Sep 20, 2010 | Canon PC1061 Copier
COPY PRINT OVERLAP AND DARK
need to replace the drum unit.
Jan 20, 2010 | Canon PC1061 Copier
Paper that was scanned is still in memory and won't stop printing
The Canon PC1061 never had a memory so I can only suspect that you have a component failure. Now try this. Place a brand new package of paper into your photocopier's paper tray. Now also lay one blank sheet of paper on the glass and run 10 copies of it. If you notice that the image that you saw before is getting lighter and lighter then most likely you just need to replace the drum unit (drum cartridge).
Dec 21, 2009 | Canon PC1061 Copier
Second blank page comes out after copies
check paper size setting and paper pickup
Jun 27, 2009 | Canon PC1061 Copier
Our PC1061 has been wonderfully reliable. Very recently we have 2 copier problems: One problem is there is frequent paper jamming coming out of the paper tray just below the toner cartridge and secondly,...
Hi:
Slide the drawer out completly and look into the cavity on the right side. You should see two D rollers that pick up the paper form the paper cassette. Clean these with alcohol. They an get dirty with time and cause paper jams.
Good Luck
Andrew
Where is the power button
it would have been indicated with some symbol. try to search by the side of ur device
Jan 18, 2009 | Canon PC1061 Copier
Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Oct 19, 2008 | Canon PC1061 Copier
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
Canon PC1061 Copier Logo
80 people viewed this question
old marine
old marine
