Question about Sony Hi8 CCD-TRV138 Camcorder
Handycam Hi8 CCD-TRV81: There is a cassette in cam. Will no play, or FF, or reverse. Eject arrow flashing, but will not eject/open
  • 10,515 Answers
Before i proceed, do you see any flashing triangle in the viewfinder?Any error message?
Thanks!!
Posted on Aug 25, 2010
SOURCE:
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
My handy cam (Hi8) has problem loading the tapes. As soon as you load the tape it will close and in about 5 seconds eject itself.
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 05, 2010 | Sony Handycam CCD-TRV81 Camcorder
HELP, I have borrowed an older camcorder from a friend. A sony Hi8 CCD-TR101 handycam. My child put the tape in backwards and now it wont eject. What should I do??
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
May 07, 2010 | Sony Handycam CCD-TR87 Camcorder
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
CCD-TRV68 hi-8 cam
Unit may have damaged loader mechanism, have it checked
May 13, 2008 | Sony Handycam CCD-TRV68 Camcorder
Cassette stuck on Hi8 hsndycam sony
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Nov 28, 2007 | Sony Handycam CCD-TRV108 Camcorder
Regarding rewind problem
The mechanism is to be replaced.
Before this check the TG assemblies for any deformation.
Then check the reel table also for any defects.
We provide spare parts for all kinds of SONY and Pansonic Models.
Aug 19, 2007 | Sony Handycam CCD-TRV12 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Sony Hi8 CCD-TRV138 Camcorder Logo
223 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
