I am having problem with my dsl router. An icon appears at the taskbar saying that I am connected to the internet but when I open a browser, it can't connect. I am using a prolink hurricane 9000p adsl router/modem.
The IP address of the router must not be the same with the IP address of you your hurricane 9000p adsl router/modem. Try to set the IP address of the other to 192.168.2.1 and the other to 192.168.1.1.
Posted on Sep 12, 2010
My Acer Aspire One was working perfectly untill today, now it wont connect to the internet either by erthenet cable or wireless, each time i click on the browser icon it thinks about if for a few seconds...
Here are some suggestions that may help you resolve your Acer Aspire One problem.
Try to eliminate possible causes by
1. Shut down / power off all the PCs - the Aspire One and those belonging to your son and daughter.
2. Shut down / power off all game or multi-media consoles that can connect to internet via router.
3. Power off any another network connected devices (hard drives, printers, scanners, picture frames)
4. Power off your wireless router and cable/dsl modem for about five minutes.
5. Power on your cable/dsl modem.
6. After a couple of minutes, power on your wireless router.
7. Power on your Aspire One and a few minutes after desktop is loaded, shut off its wireless.
8. On the desktop's Taskbar, make sure the Wireless Network Connection icon has a red x beside it.
9. Look for the double-screen icon representing Local Area Connection in the desktop's Taskbar.
10. If not there, click start, control panel, network connections and right-click Local Area Connection.
11. Click enable on the pop-up to enable the Local Area Connection and its icon appears with red x.
12. Connect ethernet cable from one of the router's RJ-45 LAN ports to Aspire One's ethernet port.
13. The red x should disappear from the double screen icon in the Taskbar.
14. Hovering your mouse cursor over the icon should get a pop-up with the connection's status.
15. If OK, click on your IE browser icon on the desktop.
16. If nothing happens, click start button at bottom left and click on IE in start menu or program list.
17. If nothing happens, press Ctrl and Alt and Del key together to bring up Windows Task Manager
18. In WTM, click Applications tab to see if IE Task is running.
19. If not, click Processes tab to see if iexplore.exe process is running.
20. If not, check if you can start anything else such as Notepad.
21. If nothing starts, you should consider doing a recovery using Acer eRecovery Management.
22. If IE does start, click on its Tools tab then click on Diagnose Connection Problems...
23. Follow on-screen instructions to diagnose your connection problem.
24. If successful, close down IE, remove ethernet cable and restart the Acer Aspire One.
25. Disconnect the ethernet cable and turn on the Acer One's wireless with its wireless switch.
26. Big green letters "Wireless LAN Enabled" should appear momentarily at bottom of desktop
27. Followed by a pop-up balloon over the Taskbar's wireless icon announcing connection made.
28. Open IE browser again, click on its Tools tab then click on Diagnose Connection Problems.
29. Follow on-screen instructions to diagnose your connection problem.
30. If OK, the problem may be an interaction with one of the other networked devices/systems.
31. Redo this procedure but power on one of the other devices/systems before the Aspire One.
32. Redo one at a time for each of the other device/systems.
33. If the Aspire One is found to be OK with all of the devices/systems connected one at a time
34. Then the problem may be when ALL of the devices/systems are on and connected.
For example, depending how it is setup, the router's DHCP may have run out of IP addresses.
Another example is IP address conflict due to systems not flushing their IP cache on restarting.
These two examples assume the problem exists regardless either on wired or wireless connection.
If just one of the devices/systems is causing the problem, it may have been infected with a virus.
Jan 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to hook up the Linksys Wireless-N WRT150N Router to DSL?
Connect the dsl modem to port on the router that says Internet
connect 1 pc to any available port on the router(1,2,3,4).
Open your browser and type 192.168.1.1 in the address bar
It will prompt for a username/password window. leave username blank,password admin. Press enter
Normally if you have dsl, you need to set the internet connection type to pppoe and put in your username and password that your ISP provided you. then save the settings.
Oct 04, 2010 | Linksys Wireless-N WRT150N Router
I'm trying to set up my netgear WGT624v3 router with AT&T DSL. I used to have broadband and used the netgear router. Switched to AT&T DSL. Internet is much faster when I go from the modem to the...
Please follow steps to configure your router with AT&T
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
(still doesnot work then click on basicsetting, it will say does your internet connection require login,you need to click on NO then very bottom there would be router mac address you need to select USE COMPUTER MAC ADDRESS then click on apply
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolve issue
Thanks for using Fixya
Apr 17, 2010 | NetGear WGT624 Wireless Router
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
Cannot Connect to the Internet Using a New D-Link DSL-2640B
1. Make sure you have the latest firmware
2. Restore to factory settings first. This helped me with stacked ppp session.
3. Setup your connection according to ISP
4. If you have problem, install Router Commander from www.routercommander.com
5. Setup router to send syslog to your PC
6. Check syslog messages about the clue what's going on
Dec 17, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Acer Travelmate 2480 Internet connection
Try to right click the Icon of internet connection on the taskbar on your right hand side right click the connection then click open then connection,then right click the current connection,then click on properties,then networking,protocols.then let the computer obtain the IPadress automatically and DNS Server address automatically.then try to browse again.
epamost@yahoo.com
Mr CPU.......
Mar 25, 2008 | Acer TravelMate 2300 Notebook
Router problem
Make sure you have the wireless icon on the taskbar lower right side. If it does not show connected, click the icon and search for wireless devices, you should see the router. connect to the router. Also make sure you have a solid DSL/CABLE status light on the service modem. BPCS
Dec 28, 2007 | Linksys WRT300N Wireless Router
DSL/dialing connection?
No, the router will do the connection for you. All you will need to do is open up your Internet browser and you will be able to connect to the Internet without having to use the connection icon from your DSL provider. If you are still unable to browse the Internet but the Router screen does say it is connected try restarting the computer.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
DSL
Feb 16, 2006 | Belkin (F5D5230-4) Router
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
