Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Need to open my nat for xbox live and playstation network
  • 708 Answers
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Posted on Sep 30, 2010
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I do not know how to change my NAT setting to open on Xbox Live
First of all I would just like to cover the basics of strict and moderate NAT settings. For those interested, NAT stands for Network Address Translation and is used to prevent problems with information being sent over a shared network.
With the XBOX 360, Microsoft have defined three categories of NAT. These are:
1. Strict
2. Moderate
3. Open
You can see the NAT level for your XBOX Live connection by going into your
1. System blade
2. Network Settings
3. Test Xbox Live Connection
For you question on how to open your NAT setting follow the steps below:
1. Type the IP address of your router in a web browser.
2. It will prompt you for a user name and password once connected
3. After logging in you will have a control panel of setting up different settings in your router.
4. The IP address, and default user name/password are different on every route
Note: 192.168.1.1 is a pretty common address for most routers.
5. Check the manual that came with your router for that info.
I also provided a few links below of password lists of different routers.
Click Here
Click Here
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
How do you change NAT type from strict to open
I've seen many guides on this subject, here you go =)
Basically you need to connect to your routers IP the same way you would go to any ordinary website, if somebody set up your network for you, for example your dad, you might want to ask him to help you out.
http://www.xbox360forum.com/forum/xbox-live/54067-how-open-nat-xbox-360-a.html
Mar 30, 2010 | Activision Call of Duty 4 Modern Warfare...
Xbox live cod mw2
Xbox nat setting
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Mar 07, 2010 | Microsoft Xbox 360 Controller
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Xbox live does not work properly
nat is quite crazy when it comes to the xbox, their are many ways of changing your nat back to open here is the easiest, on network settings on your xbox change the network from manual to automatic or from automatic to manual if you don't know how to make your network from automatic to manual go get a computer with wirless internet connection, *note the next steps i am about to tell you are for xp if you have vista or windows 7 you might figure out what im doing and use the vista or win7 way to pull up the info if you need to know* go to start, connect to wireless connection, support, details. these are the information you need to know write all of them down then type them in on your xbox but when you get to ip address type everything in but the last number and instead of the writen last number place a number one above it like if the last number was 4 the place 5 but if you test network and that does not work make it 6 ect. then your nat will be open again.
Dec 23, 2009 | Linksys Wireless-G Broadband Router
Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
Sep 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 not connecting to online parties or games
If there is a firewall or a router between the Xbox console and the networking hardware, and the Xbox LIVE test reports a NAT problem, you may have to make configuration changes to enable communication on the specific network ports that are required by Xbox LIVE. This will not guarantee that this will give you an "open" NAT status, but it may help.
If you are using an Xbox LIVE-compatible or Windows Vista-compatible device with the correct firmware installed, you do not have to manually open any ports. For a device to gain "compatible" status, the device and the firmware must perform specific functions with Xbox LIVE. These functions include (but are not limited to) setting NAT to "Open" and having the ability to connect multiple consoles to a single router. For more information about how to find out if your networking hardware is compatible with Xbox LIVE, click the following article number to view the article in the Microsoft Knowledge Base: 944293 (http://support.microsoft.com/kb/944293/ ) How to find out if your networking hardware is compatible with the Xbox LIVE Service If your device is not on the compatible list, you can try opening the following ports:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
For information about how to configure port settings on a firewall, a router, or a gateway, please see the documentation that was included with that device or contact your network administrator or local technical support for help. You can also check the xbox.com official forums to see if other users have the same problem.
If you use a Windows Vista-certified or Xbox LIVE-certified device and the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," verify that the device has the current firmware. For information about Xbox LIVE-certified devices, such as the correct firmware version for the device, please visit the following Xbox Web site: http://winqual.microsoft.com/HCL/ProductList.aspx?m=v&cid=712&g=d
Mar 25, 2009 | Microsoft Xbox 360 Console
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
147 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
