Question about Lightolier Ivory Galaxy Slide Dimmer Switch 600w X600-i
In my electrical box, I have one black, one white and one ground wire coming in. There is a single pole switch in the box now. Black goes to one terminal, white to the other terminal, and the ground to the ground terminal. The single pole dimmer switch I have has two black wires and a ground wire. How do I wire this? Everything I have seen online is a 'middle of the run' version with 2 blacks and 2 whites in the box, but I only have one black, one white and a ground.
  • i_haddow Aug 26, 2010
    This can be tricky.
    First we need to find out how many wires there are in the box holding the fixture because it could be wired "end of line", or it could be sharing wires with another run.
    If there are only one of each at the fixture the circuit is "sharing" wires elsewhere. This is tough to figure out.
    If there are two or more of each it gets easier because the switch is now "end of line".
    If the switch is "end of line" then the white wire at the switch is acting as black (wrap a piece of black electrical tape around it to remind yourself.
With just two wires other than the ground in the box, both of which were connected to a single pole switch, one must be the incomming power and the other is connected to the load. You can find out which is which either by opening up the fixture box where you will probably find that it is conneted with two white wires or by very carefully positioning the wires so they each are far from touching anything, turning the power on, and testing to see which is hot.
If the dimmer you have does not require you to know the difference between the hot and load wire, then just connect the white and black wires to the dimmer. As the previous poster said, the white wire should have black tape on it.
Posted on Sep 02, 2010
Installing Leviton 5601 single pole switch to replace an old timer switch. The box has two black wires and one white wire. How do I connect to Leviton switch?
Dear Dean,
Generally speaking, black indicated "hot", like the color of "burnt". White indicates the color of ground. ( ice or snow)
One of your black wires should be "incoming" ( that means have electricity in it NOW", and the other one would go to where the item was that was timed.
After you find which wire is "hot", the other black wire goes to the opposite side of the switch.
You may need to reverse the black wires if it is wired backwards to the ":on" & "off" readings.
The ground would be the white wire.
If you have a green screw, the ground (white) could go there.
Mar 20, 2017 | Leviton Hardware & Accessories
Replacing a single pole switch with a Leviton decora motion sensor switch do both black wires from original switch connect to black wire of new switch and white wire to red wire
The old single pole switch has 2 black wires.
One black wire is hot from circuit breaker box, and the other black wire goes to load (light, fan, motor)
New device has black wire: connect this to hot from circuit breaker box.
New device red wire: connect this to load wire
New device has white wire: connect this to Neutral wires.
Neutral wires are white wires that are twisted together and covered with wire nut and pushed to back of box. If your box does not have neutral wires, then connect device white wire to bare ground wire.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
Hi, How do you wire a Leviton switch to the next switch in a 4 gang box? Diagram? Thanks! Michael
Switches are not identified.
Single-pole switches are wired differently than 3-way.
Wire colors are not identified. Some boxes have red and black wires that carry power.
Add a comment and fill out details after studying image and reading information.
I am not there, so you can also add a comment and include in-focus photo of your switches that you posted on Flickr.
Following image shows single-pole switches, with typical black and white wires.
No bare copper ground wire is shown. Ground wires connect to green screw.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
So your new switch has 2 brass screws. No white wire connects to single-pole switch. One screw will have 1 black wire that goes to light fixture. The other screw will have 1 or 2 black wires that jumper or connect to the other switches as shown in image.
White wires are usually twisted together and covered with wire nut and pushed to back of box.
Upvote the help.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
May 21, 2011 | Leviton 15a 120v Sp Switch
I have a Intermatic Wall Timer Model EJ500 and I only have 3 wires and can I usethe Wood Model #59028 and where can I get one if it works. I had a single pole switch when I installed the Intermatic. The...
Yes you can use 59028 if you have Neutral or bare ground wire.
EJ500 is battery operated.
Woods 59028 uses electricity to power internal electronics. Like plugging in alarm clock so timer mechanism works.
That's why 59028 has white wire and EJ500 does not.
EJ500 can be used for 3-way switching, so it has extra red wire that is capped off in single pole operation. EJ500 blue wire connects to Load (light,fan, motor)
59028 is for single pole only. The red wire connects to Load.
Here's how to wire 59028:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
1) Timer-green-wire connects to bare ground wire.
2) Connect 59028 red wire where EJ500 blue wire was connected.
3) Connect 59208 black wire where EJ500 black wire was connected.
4) When electric box does not have white neutral wires, then connect timer-white to bare ground.
5) Turn on electricity, and push door on 59028 timer to activate on-off override. If Load comes on, timer is wired correctly. If Load does not come on, then reverse timer-red and timer-black wires.
Jan 18, 2011 | Woods Hardware & Accessories
I have a ground and white wires and a black wire... which do I hook to what... can I put green ground, and black with black, but can't i put my red and white on the white? For 7-Day Digital in-wall timer...
Utilitec 7-day timer will only replace single-pole switch.
Single pole switch has two brass screws and a ground screw.
Links below show wiring for both Utilitec 7-day timers
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
If this is not your timer, then add a comment and specifically state which timer you have and which wires came off which screw on old switch.
The best way to start is to identify exactly which wires came off old switch.
How to wire
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If the free answer is not right for you, then take advantage of fixya phone service.
Expert helps you via phone for a price.
Dec 30, 2010 | Garden
How do you wire a 3-wire timer switch (white, black, red) to replace a single light switch to a front door light?
You have a 3 wire in-wall timer.
Colors red black white
You are replacing single pole switch that has 2 wires (plus ground, we'll ignore ground for now)
So switch has 2 wires:
1 switch wire goes to Load/lights > this wire connects to timer red wire
1 switch wire is Hot from breaker > this wire connects to timer black wire
When finished, if lights do not turn on, then reverse red and black wires.
Timer white wire powers clock inside timer.
To complete circuit to clock, white wire is connected to neutral wires.
Located in back of electric box are white wires twisted together and covered with wire nut.
These wires are neutral, connect timer white wire to these wires.
If box does not have neutral wires described above, connect timer white to bare ground wire.
Add a comment any time
Dec 10, 2010 | Hardware & Accessories
I have an ST01 timer that I want to place in a three way circuit that appears to be different than that shown in the directions. My circuit has power (black/white/ground) coming into switch 1 with a three...
One caveat of most In-Wall electronic switches/timers is that the device _must_ be installed at the switch box that has the power, in your case switch #1. In order to install it at switch #2, in your case, you need an extra wire between the switches (to carry the HOT wire), and unfortunately, the bare ground(ing) wire is not permitted to be used to carry current per National Electric Code (NEC).
In your case the wiring for the ST01 is as follows:
Switch box #1: Connect the incoming White wire to the White wire in the 3-wire cable that goes to switch box #2. Connect the incoming (Black) HOT wire to the Black wire on the switch/timer. Connect the Red wire in the 3-wire cable to the Red wire on the switch/timer. Connect the Black wire in the 3-wire cable to the blue wire on the switch/timer. Connect the green wire on the switch/timer to the 2 bare ground(ing) wires. If you have a metal box this connection should also have a pigtail that connects to the box with a green ground screw.
Switch box #2: Remove all of the existing wires from the 3-way switch. The three-way switch will have 2 screws the same color (usually black) and 1 screw (usually brass). For this scenario, one of the black screws will _not_ be used.
Connect the Black wire in the 3-wire cable coming from switch #1, the Black wire going to the lights, and a short Black pigtail together under one wirenut. The pigtail is then connected to the brass screw on the 3-way switch. The Red wire in the 3-wire cable coming from switch #1 is connected to one of the 2 black screws on the 3-way switch (pick one).
In effect you are installing a single switch at switch box #2. In fact, you can use a regular single pole switch if you want too.
To finish, connect the White wire in the 3-wire cable coming from switch #1 to the White wire going to the lights.
Grounding is the same as switch #1 except you'll need a pigtail to connect to the green screw on the 3-way switch.
That's it. You may want to check the battery compartment in the switch/timer, as sometimes they put in a pullout plastic tab to keep it from being energized until needed.
Now, the E1210 is a different animal, and can only be used to replace a single pole switch. You could use it by basically passing the power through to switch box #2 from switch box #1 and then cover switch box #1 with a blank plate. The ST01 could be used that way too, in which case the black on the device connects to the hot, the blue to the lights, and the red on the device is not used, nor will the Red wire in the 3-wire cable between the switch boxes be used.
Sep 11, 2010 | Intermatic EI210 Electronic Auto Shutoff...
How do you wire a Two Single Pole Switch for each switch to run seperate lights all off of one circuit. Example: Recess Lights on one switch and a Track light on the other switch. 6 black wires, 6 white...
so 6 grounds is connected together, and conneted to mains ground (direct connection), the white wires is (mains Neutral) and you connect all 6 white wires together (to doble pole safety switch) in one end pole switch, and you connect a wire from another pole the same end at common Two Single Pole Switch and connect (Black wires recess lights) to one free pole switch and (Black wires track lights) to another free pole.
The mains connect to safety switch live (Black or Brown) to another free safety switch pole, Neutral (White or blue) to free safety switch pole and earth to ground wires on mains connector.
Note: Allways use a mains 300mA diferencial safety switch, for better protection.
Jan 02, 2010 | Computers & Internet
I have a live 2-wire line that used to be connected to a light with a switch built into the light fixture. I removed the fixture and put wire nuts on the live wire. What I'm trying to do is to wire the 2...
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Oct 17, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
Lightolier Ivory  Galaxy Slide Dimmer Switch 600w X600-i Logo
157 people viewed this question
Top Lightolier Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Lightolier Electrical Supply Expert? Answer questions, earn points and help others
