Question about Behringer EUROPOWER EP2500 Amplifier
I have a EP2500 power amp running 2 Harbinger 500 watt subs....... The Harbinger subs our 8ohms each, I'm running the Ep2500 in the bridge mode.....one of the Harbinger Subs is quite a bit louder then the other one.... they should be the same volume???? more infor....I'm using a Behringer super X Pro Crossover and taking the bass feed out and going into the EP2500........any reasons you can think of that one sub is louder then the other how can I troubleshoot this problem...Tom
3 Suggested Answers
SOURCE: howto or if i can run 4 speakers off of ep2500 what settings do i use
  1. i need to adjust the bass from the amp can this be done please
  2. how do i run bass bins and tops from only two channels please
  3. can you get me a manual for the ep2500 please
Posted on Oct 11, 2008
SOURCE: how would i conect a
If each PV speaker is 2000 watts program at 4 ohms then bridge each amp and run one speaker per amp on a bridged channel. One behringer amp bridged to one 4 ohm 2000 watt program speaker. just be careful not to over power the speaker because you will have 400 watts over your 2000!!! I suggest using a limiter or make sure your gain structure is dialed in or POOOF!!! I hope this helps you also keep in mind that the ohms load in bridge can not go under 4 ohms.
Posted on Feb 23, 2009
What wattage speakers do I use with europower ep2500
Wow thats a serious system you have there.God help the neighbours!Anyway here is an example.you need a pretty serious speaker.At 8ohms,you would need something like a 8ohm 450watt speaker system.Anything smaller will stress your amp if you turn it up.The amp would kill smaller speakers or the amp internals(channels)at higher volume.It would be like hooking up a garden hose to a fire hydrant.Something would have to give.hope this helps and happy listening
Oct 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Proper mode settings
Hi bongodboss
The user manual for this amp has good instruction on how to connect it. You can download a copy from here.
Page 9 has info about using the amp for "bi-amping" The amp is only a stereo unit, so to do a 3-way system, you will need at least 1 amp mono in bridge mode for lows, and other stereo amp for mods, and another stereo amp for highs. You could use the internal low pass filter for the bottom end, and a 2 way crossover for the mids and highs. Much simpler doing a 2 way system with composite bins for mids and highs, and subs for lows. You only need the 2 amps and use the low and high pass filters inside the EP2500. If you need anymore help on this, I am happy to talk to you more.
regards
robotek
Jul 10, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
61 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
