Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Sensor open left side not getting cold and torque sensor says hold ultra button for three seconds
    President:
  • 1,618 Answers
This is going to be a project:
1, the hold for 3 second on the ultra button is for the filter in the back which needs to be clean, then machine needs to know that it is clean so that it can reset counter for the next 3 months.
2, The torque sensor is behind the unit covered by the white or black plastic cover under the powder unit, you will see 2 screws holding cover on. The reason it is getting the error is because the 2 pins on the auger shaft are covered in product or the sensor card is damaged(most likely it is the product issue). You will need to perform a shaft seal maintenance on the machine.
Posted on Aug 26, 2010
Why is slush machine only freezing on one side
if it's a cab faby and it's the right side not freezing but getting cold, you have low refrigerant. if it's warm, you have a stuck solenoid, blocked capillary tube, or a bad torque micro switch. if it's a bunn ultra 2, you have a bad solenoid or the freezing button is not on freeze.
May 16, 2014 | Kitchen Appliances - Others
How to fix right side torque error
open the back cowling on the side that has the error (might as well do both) and remove the 4 screws that hold the motor mount to the machine. pull the motor back and unplug it. you'll see an optic sensor board to the right of the shaft on the machine. clean off any dust from the sensors with a q-tip or compressed air. there should be 2 pins on the end of the shaft. if there is only one, you need a shaft assembly. reassemble and test it out.
Oct 23, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Bosch 500 series front load washer less than 6 months old. Getting code E27 when turning it on... suggestions before I call service?
E27 means there is a problem with the door lock.
Unplug the machine for 30 minutes and try again. If the error code returns you will need to replace the door lock assembly. Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Replace the door lock assembly on the washer. Refer to your washer manual for the correct part numbers.
Check to see if your Bosch washer is still covered under warranty. If so, you could receive free replacement parts and service for the faulty door locks.
Hope this helps (remember to rate and comment this answerr).
Jul 16, 2011 | Bosch Evolution 500 Series B20CS51SNW 20.2...
Left side error torque
More than likely a bad shaft,Part # 32449.0000.This machine when there is a problem tells you exactly what part went bad.Could also be the torque sensor board,Part #27939.1000.Alot of the problems stem from not lubricating the front nose seal (auger).
Jan 20, 2011 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
Help! I have a kenmore elite ultra wash quietguard delux. the other day my toddler was playing near it so i pressed the button to lock it. Problem is I don't know how to unlock it! Please help me...don't...
Here are the instructions to set and unset the child lock.
Setting the Child Lock:
1. Press the Sensor Dry or Lock pad and hold for
three seconds.
2. An indicator light next to the lock graphic will
illuminate when the controls are locked.
To cancel:
three seconds.
2. The indicator light will go off.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
271 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
