I bought rs turbo last october
I have a cert of installation for immobiliser
Immobiliser now broken
cannot contact installer (think gone bust)
now can't start car
how do I imobilise the imobiliser
When you say the Immobiliser is broken... Do you mean the touch key? The 8510 touch key is prone to the internal contacts failing. If you open the case up and reconnect it then you should be able to disarm the immobiliser You should have two touch keys so try your spare on first. Be warned... You will need 1 working touch key to program a spare or the system will lock out and will need replacing
Hope this helps!
As for Sutty
Sounds like the system has lost power if the LED is not flashing. Have you made sure cars the battery is not flat?
The touch key pad has broken and fallen inside the dash on my car. I have managed to pull it back out and it still works, Are the front plastic mouldings availible ?
Comments:
Aug 31, 2008
- Hi, the immobiliser works fine. Its just the plastic mounting with the led and touch pad that has fallen to bits.
hook up jvc kd-hdr50 in 1994 ford explorer have no sound bought all the plug needed no sound from...
(More)
hook up jvc kd-hdr50 in 1994 ford explorer have no sound bought all the plug needed no sound from car speaker but connect a spare speaker to back of radio work fine need help?
Just installed jvc kd-s16 and it loses power after 5 seconds. Used proper wiring harness and...
(More)
Just installed jvc kd-s16 and it loses power after 5 seconds. Used proper wiring harness and installed in 1996 f150
