Question about RCA P56923BL 56" Rear Projection Television
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
6dpicture looks like 3d  i have ajusted screen but - fcabb43.pngclass=
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Posted on Aug 28, 2010
52inch projection screen television has only red and green colors and its difficult to see the picture.
If the picture looks 3d with lines bowed it may be a convergence problem---go into the customer menu and call up convergence and at least look.
Aug 27, 2012 | Samsung PCJ522R 52" Rear Projection...
On our rca hdtv model # R52WH77.. the tv is having like a 3d look on it and has a bow in the picture.. we bought the convergance repair kit from tvrepairworld.com and replaced the 2 parts it gives us.. ...
have you reset the convergence parameters after installing the kit to fix the option? Usually you will need to reset the defaults to get the outer edges back in alignment.
Aug 11, 2011 | RCA R52WM24 52" HDTV Projection Television
My Hitachi 57F59A projection tv has a yellow color to it. I have ajusted the color and tried to reset and start over but still yellow. What could b wrong?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 04, 2011 | Hitachi 57F500 57" Rear Projection...
Av48wp30 picture is not working. crazy lines all through it with no picture or bowing in an hourglass shape. Could turn off and turn back on after a few minutes but now will not come back.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2011 | JVC AV-48WP30 48" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a scoop or 3d look how can i fix it
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
On my Phillips rear projection tv. The blue mulitipoint ajustment is not working. It will adjust left and right, but not up and down.
Screen looks 3D
Sep 26, 2009 | Philips 60PP9202 60" Rear Projection...
3d picture and looks like bow tie
Bad STK ICs replace both ICs will have part number on them STK392-110s if this is what you have upgrade to 150s! ICs are Big black ICs also ck 2.7 ohm resistors near ics.
Sep 16, 2009 | Samsung HCM4215W 42" Rear Projection...
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
The convergence box keeps going out.
this 3d effect is due to what is known as convergence.i work daily on these set in the shop. (thats a good testomony for these LOL) but the first question i ask is 1 in the customer setup do you have convergence option.. Next question is the picture bow tie looking and 3d. if you are missing the convergence option chances are it is the fl231 fuse. then you need to read the fl231 fuse under tips and tricks section of this website. Convegence is controled by three cuicit boards. if any of these need to be replace a technician may need to set or adjust the convergence back to faactory specs
Apr 18, 2009 | RCA HD56W66 56" HDTV
Televison & Video Logo
158 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
