Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The floor under my side by side fridge/freezer is wet. Opened up the back & there is a thin copper pipe which running from under the freezer to the condenser.Thisis freezing up & then the lce melts when the motor is not running. The water then runs onto the floor. What can I do?
Check and see if the fan is running. if it is see how dirty the condenser coil is sounds like a air flow problem on condenser
Posted on Aug 26, 2010
Hi there I ve got a Samsung fridge model RL34SCSW1 my freezer is working fine it's just the fridge bit is not cooling?
Good day, please check at the back, at the bottom where the compressor is located for the pencil dryer(as in photo). Get a nice firm grip on it just be careful and feel the temp if it's cold or one side is hot and the other side cold the dryer is block. Otherwise feel the thickest pipe running into the compressor it should be cold if the fridge has been running for a while and the thin copper pipe existing the compressor should be hot. If the thin pipe is freezing up with a thick layer of ice and the dryer as some med-temp then there's a gas leak. If the thin copper pipe is very hot and the dryer has no temp then there's a blockage but if the thin copper pipe feels med-temp and the thick copper pipe more or less the same but a bit cooler the compressor is not pumping also feel if the compressor is running. If dryer as a warmth temp and the thin copper pipe is hot and the thick one very cold(when tipping your finger on your tongue and pressing it against the pipe your finger should stick a bit) if all checks out then it's the thermostat switching the compressor off at the rong temp.
Personal opinion in this case I believe it's a blocked dryer or gas leakage.
Regards
Jun 09, 2016 | Samsung Refrigerators
I ve got a Samsung fridge freezer model (RL34SCSW1). My freezer is working fine but my fridge is not cooling?
Personal opinion I believe it's a blocked dryer or gas leakage.
Regards
Hotpoint ice diamond RFA52 P freezer ok fridge not cold enough, this is not a frost free and there are no vents in fridge or feezer?
Regards
Jun 09, 2016 | Hotpoint Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
GE Concept II fridge leaks inside fridge and then out to floor. Noticed that water is dripping in back under freezer where there is a cup-like part. What is the problem?
I had the same problem & I had to clean the water collector at
the back inside the fridge. It was was plugged with residue draining from the freezer. Make sure you clean the drainage pipe behind the fridge also & run some water though the whole system to clean out.
No problems for me after that.
Oct 17, 2010 | Refrigerators
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
My 40 l does not wan to keep stuff cold teh motor kicks in only mometarily, can it be in need of a gas refill and does it ide normal aircon gas? It can get cold by itself but if you stick it with drinks...
If The motor is switching on for short periods, you either have a faulty compressor or a blockage. My money is on a blockage. Once cover is removed to allow you to see the compressor, look for a small fat copper tube that has a small 1/4 inch copper pipe on one side and a thin capillary tube connected on the other side DRIER). Flex this very thin pipe connected to the small fat tube(DRIER) untill it breaks.Gas will come out. Wait untill all gas is out then reswitch on and see if compressor still continues to switch off on short intervals. If it can run for at least 1 min without switching off, then get a Refr.Tech to come and replace drier and regas unit.
Sep 23, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Jan 21, 2008 | Jenn-Air JCD2295HES Side by Side...
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
