Question about HP Pavilion dv6000z Notebook
When trying to eject my usb flash drive, I get a message-- the device "generic volume" cannot be stopped now, try later . This has been locked up for about 2 hrs. now.
    President:
  • 2,600 Answers
If you are operating Vista or Windows 7, you do not need to "eject" the disc. It is not necessary to "safely Remove" the flash drive by using the prompt in the taskbar. Just pull the drive from the computer, if the system has a lockup, just reboot it and clear the problem. The DV series laptop unfortunately is prone with problems, but this sounds like a windows lockup rather than a hardware issue.
Posted on Aug 25, 2010
  • 3 Answers
This happens when a program is still writing data to the USB when you are trying to unload it from your PC. Dont pull the stick out where possible, as this risks losing data. (Though most times it's fine in my opinion)
Generally, most people close off the programs that are no longer using the USB before they unload it but certain programs 'link' together. For example, depsite you closing the MS Word document after saving it to USB, MS Word is also directly 'linked' to MS Outlook. If your outlook is still running, this may affect it. Try closing ALL programs (where possible) and ejecting the volume.
Alternatively, download a program called "unlocker"
http://ccollomb.free.fr/unlocker/old/unlocker1.8.6.exe
This will load a popup into the menu that shows when you right click the drive from 'computer' Just click the 'unlocker' command and the drive should eject normally.
I have used my USB... when im already going to unplug it using the "safely remove USB", a notice pops out that says: <the device Generic Volume cannot be stopped right now. Try stopping the...
Hello marieborja10,
This happens some times when a program is accessing something on the drive. Make sure all files that were opened are closed. Also, make sure any open folders are closed.
If it still fails to eject, it is perfectly safe to pull the USB connector out as long as all programs/files/folders are closed.
Hope this helps!
Jun 29, 2011 | Ritek RiDATA Ultra-M N-S25-256-M 2.5 256GB...
When trying to remove the memory stick this notice appears the device'Generic volume' cannot be stopped right now. try stopping later. what does this mean and how do i fix it
1. this is a message letting you know that the computer is using a file on this drive.
2. You need to release the file in use that is close all programs then eject the flash drive properly using Windows ejection program.
c. You have checked the user manual 1st.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Jun 14, 2011 | Sony Micro Vault Pro USD-2G (SONYUSD2G) 2...
Message displays when attempting to "safely remove hardware"
You need to go to the Tool Bar, (bottom r/h side), and click on Safely Remove USB hardware. and choose your device and shut it down from here then remove.
Jan 29, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I want to eject Have Cruzer Titanium 2.0 USB memory plugged into computer. No programs or files from it are currently in use. After clicking on Safely Remove hardware, the message Problem Ejecting USB Mass...
Make sure you have all programs and folders closed. Then try stopping usb mass storage, there should be more then one option so try removing the drive itself on the list. If that doesn't work. I myself would probably just restart the computer. Then try again.
Thanks,
Lee
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The device Generic Volume cannot be stopped right now. try stopping the device again later. on Window XP
If you tried to stop your external hard drive with it open in Windows Explorer, You will get this message. You cannot disconnect the drive in this condition. Even if you close Windows Explorer after, Windows still thinks it is open. The best thing to do, is restart Windows and when the screen goes black, shut the power off to the external drive or disconnect the USB cable. Disconnecting in any other way causes Windows to have problems with USB devices in the future.
Jun 08, 2009 | Western Digital 500GB My Book World...
Problem ejecting/stopping Seagate Freeagent Go 250GB hard Drive
Antivrius or another program using it...You just need to stop all servicess on task menager then stop mass strorage device
May 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
The device Generic volume cannot be stopped right now. Try stopping the device again later
1st off, is anything transfering? then pull it out. if your using windows, its being retarded as usual.
Feb 13, 2009 | Generic Memory Electronics - Others
why not try to use a separate program to safely remove the drive.
download here
what is it?
USB Safely Remove is a USB device manager. It saves time and extends user abilities on active work with flash-drives, portable drives, card readers and other gadgets.
post back and let us know.
Feb 09, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
Ejecting of harddrive
The only reason for the display "generic volume cannot eject now, try again later" is because it is still being accessed by your PC. This may be due to considerable large file size being transferred and/or being backed up, virus scan, a utility is still doing its work.
To answer your concerns:
1. Will there be a problem ...
Normally no, but yes it does happen. It happens when the actual physical removal of the USB connector(s) is not a continuous single motion.
2. How do you eject ... Shut down/power off your PC, once off remove and reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 12, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
