Question about Maytag MEC5430BDS Electric Cooktop
One burner (left front) heats up too much. You cannot regulate the temp. Everything heated on this one element burns.
    President:
  • 1,430 Answers
This is usually caused by the infinte switch. You will need to disassemble to acess the switch. The switch is easy to test and replace. Here is a link showing how to test an infinte switch http://appliancehelponline.com/infiniteswitchvideo.html
You can also enter in your model # for diagrams and illustrations of your specific model.
Posted on Aug 25, 2010
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
Regulating the heat on Kenmore cooktop.
Bad control or infinite switch. replace the switch for that element and you will be good to go.
Jul 05, 2010 | Kenmore 36 in.43492 / 43494 / 43499...
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Jen Air left front small burner does not heat up.
these are cartridge elements corrrect? try reversing the cartidges, now the front small will become the rear small . does it not work in this position? and the newly placed front burner work?? this will determine if the proble lies within the cartridge or the switches
Feb 22, 2008 | Jenn-Air JED8230 Electric Cooktop
Maytag MEC5430BDS Electric Cooktop Logo
43 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
