Question about Sanyo VPC-S880 Digital Camera
Lense is out and says lense error 112 camera does not stay on
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 25, 2010
WILL THE ABOVE LENSE WORK WITH A CANNON DIGITAL CAMERA AND CANNON 35MIL CAMERA
Yes, it's suitable for 35mm EOS mount Canons and all digital models. If the digital SLR has an APS-C sensor then the image will be cropped and will give the same viewing angles as a 112-480mm on a 35mm camera.
Oct 03, 2010 | Canon EF 70-300mm f/4-5.6 IS USM Lens
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 03, 2009 | Sanyo VPC-S7 Digital Camera
I just got a kodak c913 camera yesterday and everytime i switch it on it stays on for seconds and then switches off, help!
My co-worker brought me a C913 with the same problem. I took out the batteries, took out the SD card, played with the buttons... nothing. A web search was unfruitfull. For fun, when I turned it on, I grabbed and held the lens. The camera turned off but the lense stayed out. I turned on the camera, the lense stayed out and the camera WORKED! I turned it off, the lense docked properly. I turned it back on, it worked... Woohoo! Theory: Either the lense was slow at coming (binding) out or was not coming out far enough. The camera shut itself off because it wasn't fully extended in an alloted period of time. Hope it works for you. Glennster™
Dec 26, 2008 | Kodak EasyShare C913 Digital Camera
Transfering my ef lenses to digital cameras
Hi Marc! Almost all EF lenses, including the two you listed will work on the Canon Digital SLRs. On the Digital SLR they will have 1.5x the magnification that they would have on a 35mm camera. Your 28-90 will be like a 42-135mm and the 75-300 would be like a 112-450mm. This is because the image sensor on the Digital SLR is smaller than a 35mm negative.
CameraRepairs
Aug 03, 2008 | Canon Cameras
Digital camera
I got a lense error 112 then the camera goes off
Jul 30, 2008 | Sanyo VPC-E760 Digital Camera
Camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 18, 2008 | Canon PowerShot A510 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Sanyo VPC-S880 Digital Camera Logo
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
