Question about Craftsman 55 Torque 158cc 22" Push Lawn Mower ()
Runs then sputters but doesn't stall, then it runs and sputters almost to a stall. The unit is only two months old. Bought new.
I have an 88 Cadillac Deville. 2 months ago I had a new fuel pump put in. It's making a whining noise and the car keeps dying and sputtering. What else could be the problem to make the pump go out?
Cadillac DeVille Questions - My deville has been stalling ...
www.cargurus.com > Questions > Cadillac > DeVille
CarGurusJun 25, 2013 - My deville has been stalling while driving when I let off gas. ... mapp sensor, maf, spark plugs, valve gasket covers, fuel pressure regular and still dying. ... 1989 Cadillac DeVille car stalls or stops what does that mean ... my 93 deville has began spitting and sputtering and lossing power air and fuel filer has ...
My car started sputtering when I was driving and just died. I ...
www.cargurus.com > Questions > Buick > LeSabre
CarGurusMay 25, 2014 - My car started sputtering when I was driving and just died. ... no- don'tkeep guessing- take it to a good mechanic in a good garage- "good" meaning, they won't be guessing- maybe you can fix it .... Used Cadillac DeVille".
Rough Idle Due to EGR Valve Sticking Open : Cadillac ...
repairpal.com > Problems > Cadillac > DeVille
Dec 28, 2015 | Cadillac Cars & Trucks
93 chevy s10 starts but then sputters and stalls
Have you checked the fuel pressure yet ?
Has the fuel filter been replaced in the past 12 months ?
Feb 16, 2013 | Cars & Trucks
1987 olds cutlass ciera, idles fine, but sputters and dies when driving.. restarts no problem but getting progressively harder to keep running and harder to restart.. problem worsening quickly.replace
the most problem was the MAF sensor. to check it engine running and tap a little with a screwdriver handle on the maf sensor if it stall .the maf sensor has to be replace.
May 17, 2012 | 1987 Oldsmobile Ciera
Why does my 2004 Trailblazer run rough at stops and AC is on? Doesn't stall and temp. is fine. Also idle gage seems fine. It also sputters when shutting engine off. Just had the motor mounts...
ONe of the "easy" fixes is buy a can of throttle body cleaner. Remove the air intake near throttle boddy and clean the inside of throttle body as best you can this should help it. If it doesnt have it checked out it could be more advanced problem. Good Luck.
Sep 09, 2011 | 2004 Chevrolet TrailBlazer
Chain saw runs great until I start cutting tree, then it stalls out. I've only used it three times since I bought it last month.
I would say its running too lean, start by replacing the fuel filter in the tank, check the fuel hose up to the carb for leakage, if this does not help unscrew the H screw on the carb 1/4 turn anti clockwise, this will richen the fuel mixture, does this help the running? if not there may well be a fuel blockage in the carb.
Jun 04, 2011 | Poulan Pro Chain Saw 46cc 20"
Remote not working tv only 5 months old
If changing the batteries doesn't fix it then call wherever you bought it or whoever made the TV and get it repaired or replaced. Unless you bought it somewhere you shouldn't have, this unit has a one year manufacturer warranty and they will pay to have it repaired or replaced. Good luck.
May 01, 2011 | Televison & Video
My troy bilt snow blower that i bought last season (new) ran great i drained the gas at end of winter and this year is hard to start and runs poorly stalls often and bogs down spits and sputters and also...
I am guessing you did not run a gas stabilizer through the unit. Start the unit and run it while spraying carburetor cleaner in spurts into the carburetor. What has happened is that the small amount of gas has dried or what we call varnished causing internal parts to stick. If that fails, removed carb and disassemble and clean, reinstall.
Dec 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Other times my car will stall, sputter, **** while driving and seems to not be getting gas. Even going 70 down the highway it will stall. When it stalls while driving the dash lights come on.This happens...
check for corrosion on the sparkplug wires, both ends. Crankshaft position sensor, cam position sensor and lastly, gulp, the ignition control module..
Sep 07, 2010 | 1994 Buick LeSabre
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman 55 Torque 158cc 22" Push Lawn Mower () Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
