Question about Intel Motherboard
Computer Freezes on Internet
I am relative newbie hoping that someone can help me with my problem - I've googled for days and haven't found any leads.
My Machine:
AMD Sempron 2400 processor (1.6 GHz)
K7S14GX motherboard
1 Gb RAM
WDC WD 800BB-00JKC0 Hard drive
OS: Dual Boot WinXP SP2 / FreeBSD 7.0-Release
Hard-wired to a wireless modem/router (Two other machines wirelessly sharing internet connection - no problems.)
The Problem:
My computer hangs when I go online in either WinXp or FreeBSD. It happens randomly - after 5 minutes or an hour and a half - and I have to do a hard reset to reboot my machine.
History:
This started about a month ago. Initially I thought it was my DSL ISP (Bell Sympatico.ca), so I called them and they said my line was fine. I had been using their hi-speed modem with my own Linksys wireless router. They sent me an upgraded modem - still no improvement. I suspected that maybe my problem was my router - it is an older model - so I purchased Bell's combination router/modem. Still no improvement.
I have started preliminary testing with MemTest and SmartMonTools but so far everything tests fine. I have to assume that this is a hardware problem as it affects both operating systems equally. I even updated my BIOS, but still no improvement. I have done clean installs on both WinXP and FreeBSD several times to no avail.
This machine has been trouble-free before this incident, and WinXP and FreeBSD have coexisted peacefully for years up until now. Any comments, suggestions, or advice would be gratefully appreciated.
Regards,
Larry
  • 2 more comments
  • lwptg May 06, 2008
    Thanks for the speedy reply! I'll try connecting to the net with a wireless NIC and see what happens. (After I disconnect my network adapter in the BIOS...)
    Thanks again,
    Larry
  • lwptg May 07, 2008
    Well, I purchased a D-Link ethernet card as well as a new network cable. I installed the card after a clean install of WinXP. No change, it still hangs. And it doesn't seem browser related as it hung when I pinged (pung?) yahoo.ca.
    I know that this type of problem is very difficult to isolate. I am thinking that I may just have to buy a new computer. Any other suggestions, comments, or advice would be greatly appreciated.
    Regards,
    Larry
  • lwptg May 08, 2008
    Just to let you both know the outcome to my problem: I disabled APCI in both WinXP and FreeBSD and the system works like a charm - hasn't frozen once in 24 hours of being online in both OS's.
    Two short questions, however:
    1) Are there any downsides to disabling my APCI?
    2) Why should this adjustment have to be made after several years of working just fine? I didn't add any new hardware or software.
    Regards,
    Larry
  • drk350 Nov 11, 2008
    installed bell sympatico and a linksys wireless -n pci adapter and my computer freezes now
As far as functionality goes, disabling APCI will have no affect.
APCI stands for application-layer protocol control information. It is normally used in the industrial field to help monitor equipment performance. At least that is what I found when searching for APCI. It works with ethernet and IP to transmit the data to the user interface.
In terms of why it needed to be disabled, there could have been a recent security patch installed on your machine that prevented APCI from accessing the network. Even on a new install, Windows searches for recent updates that your computer does not have, then automatically installs them.
markk7171
Posted on May 08, 2008
What Firewall are you using?
Posted on May 07, 2008
    Sergeant:
  • 221 Answers
Possible problems: If you've replaced both the modem and the router more than once and you still have the problem, then the problem is with your machine, especially considering that two other computers can connect wirelessly without difficulty.
Assuming that the only time your computer freezes is when you are on the internet, most connection oriented issues, such as the one you are describing, are a result of poor or faulty physical connections. So you are correct in thinking that it is a hardware issue. If you haven't replaced the cables between your computer and the router/modem, do this first. If that does not solve your problem then I would say it could be your network adaptor, which is the device that you plug the cable into on the back of your computer.
Most computers have a network adaptor built into the motherboard, so you will need to purchase a pci adaptor and place it into one of the available pci slots on your computer.
After doing so you will want to go into the bios and disable the old adaptor so there are no conflicts. Run the setup disk for the new adaptor and try it out.
On the other hand, if your computer does freeze at other times when you are not on the internet, then the problem could be one of many other possible causes.
Posted on May 06, 2008
When I am reading my e-mails, my computer freezes up. I have to log off and then restart it. What is wrong
A computer locking up or freezing is often is caused by software related issues. ... Tip: If the computer has any malware, virus, or other malicious software it can also cause many problems. Make sure your computer is clean. Too many programs open.
Windows freezes or stops responding. - Computer Hope
www.computerhope.com/issues/ch000690.htm computer freezes up Google Search
Dec 07, 2016 | Computers & Internet
My computer has a virus . I 've been around
Please try to install the Kaspersky internet security 2012 by downloading trail version.
Better to install this in SAFE MODE with NETWORKING . By pressing F8, you can get the options like safe mode, etc...
Otherwise, please remove the harddisk and attach to another pc or laptop externally and SCAN this hard disk completely with Kaspersky internet security 2012. Before you attach this virus hardisk to another system., please install the good system with Kaspersky internet security 2012..
Hope this helps to you..
Jun 29, 2011 | Acer Computers & Internet
How to create my own website?
If you would like to create your own free website you can try Google Pages. You have to be registered with google to use this feature though.
If you are a yahoo member you can try Geocities.
Jan 31, 2010 | Computers & Internet
Error 0 (net::OK): Unknown error.
Hi there, try to reinstall Google chrome, you do it in this way :
Uninstall chrome, reboot the computer, install google chrome again :O)
Hope that helps
IF NOT then return here
Have a nice day
Please rate my answer
Oct 11, 2009 | Google Chrome
OLYMPUS DS-330 Drivers
Hi Aklas.
Olympus DS-330 voice recorder drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Nov 05, 2007 | Olympus DS-150 Digital Voice Recorder
1934 installation problem
I have no magic solutions for this problem, and I?m guessing you?ve already tried what I?m going to suggest, but if not maybe you should try that: 1. are you using a laptop? The card you?re using might be a Cardbus, which usually isn?t supported by laptops because of BIOS settings. 2. It might also be a driver problem. Disconnect the card, remove it, remove the drivers. Restart the computer and reinstall the drivers. Turn the computer off. Reconnect the card and only then turn the computer on again. Wait a few minutes (sometimes it takes a few minutes for the computer to recognize new software). I don?t know if it would work, but it?s worth giving a shot.
Feb 22, 2006 | Artronix Technology Firewire 1394B...
Intel Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
