Question about Technics SA-AX530 Receiver
My receiver says power overload and then tells me to switch it off. is this something i can reset or is it blown
  • 4,472 Answers
Check your speaker connections, or unplug all your speakers and verify the problem still happens. If so it is an internal problem and most likely not worth getting repaired.
Thank you,
Lee
Posted on Aug 25, 2010
Russsound a c68 Will not stay on
These units must have a safety system that is detecting an overload, the same way a fuse would do by blowing. The fact that you are getting some power to the system means that any fuse must be intact.
You have to find the cause of the overload and correct it and the safety circuit should go back to normal. It's likely that the overload is a short circuited transistor or something like it.
Mar 26, 2016 | Audio Players & Recorders
My Hobart H-600 commercial dough mixer shut off in the middle of grating cheese now it will not turn back on
Google perhaps a fuse is blown something was to heavy or something was under tension to the power supply that so the machine did not get the required voltage by too much taxation by other devices on the power line group
Oct 15, 2015 | Hobart Food Mixers
Overload what do i press and hold to reset?
This is an old receiver. Probably something simple like leaving it unplugged would do.
Sep 06, 2014 | Technics Audio Players & Recorders
Does the onga spa master 4352 have a fuse or overload switch?
try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
Aug 19, 2014 | Pool & Spa
Working on for friend. Unit does not power up, no fuses blown
The most obvious place to check is anything to do with the power supply, such as the transformer. A fuse will only blow if an overload occurs, caused by something acting like it was just a piece of wire. However if something acts like a broken wire, everything justs stops dead and the fuse doesn't blow!
Jun 14, 2010 | Sony STR-DE698 Receiver
Major power surge/outage & JVC won't stay on. Clicks on and starts to cycle, then shuts down. Fuse blown? Reset button somewhere? or trashed?
If appears "OVERLOAD" before turn off, you ned change a couple of resistors of 10 ohms at 5 watts near the digital board (Optical inputs)
Apr 19, 2010 | JVC RX-9010V Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Overload
internal wickman fuses blown check speakers high unts tweeters\ gone short primary transistors /ic blown
Dec 31, 2007 | Technics SA-DX940
Overload
I know that this post is long outdated, but I came across it and had to post.  Sorry, but the solution posted by nfanres is not correct.  Just because the KLH speakers are rated at 250W does NOT mean that they will always pull that much from the receiver.  That is just a manufacturer rating saying that they recommend supplying a max of 250W to the speakers.  The reason your receiver says "Overload" is most likely due to the subwoofer being an improper impedance for the receiver, causing the receiver to see a lower resistance in the load, and thus outputting too much power.  I could go into a detailed explanation as to why with Ohm's Law, but just suffice it to say that if you decrease the resistance, current will increase, thus the overloading (too much current draw for the receiver).
If you haven't already, try just unhooking the sub and going back to the setup you had before.  Generally, Pioneer receivers are protected, and just say "Overload" and shut down everything so that nothing fries.  If you have already tried that, then I don't know what to tell you - something must have internally tripped.  You have probably either gotten rid of the receiver or fixed it by now, but I just had to post and clear this up for anyone else who might have a similar problem.
In short, ratings on the backs of speakers do NOT mean that they pull that much power.  It's just a rating of how much you can push from the receiver to the speaker.
Feb 02, 2007 | Pioneer VSX-D411 Receiver
Technics SA-AX530 Receiver Logo
111 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
