Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
How to change pump belt on bissell pro heat - Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
  • Anonymous Dec 06, 2008
    hoover max
    President:
  • 1,673 Answers
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Posted on May 13, 2008
No print is too small
Posted on Sep 08, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat brush is not spinning. the belt is on and spinning but brush is not moving
There are two belts a brush belt and a pump belt. For a kit with installation instructions contact
BISSELL Consumer Services at
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 19, 2011 | Bissell Vacuums
I need to change the belt on my Bissell Pro heat. I dont know how to get to it!
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bncmdgh
May 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Does the bissell pro heat have one or two belts?
The Bissell Model 25A3 has two belts, a pump belt and a brush roll belt. The pump belt (Bissell Part # B2150628) is flat and runs from the motor to the pump. The brush roll belt (Bissell part # B0560621) is cogged and runs from the pump to the brush roll. See key numbers 34 and 36 below.
May 17, 2010 | Bissell 25A3 Upright Vacuum
How do I change the belt on my Bissell Pro Heat
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No spray
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Feb 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
167 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
