SOURCE: ge motor c474
Typical Diagrams Will Be As Follows
C - Common
H - High Speed
L - Low Speed
_____________
W/white - Common
B/black - High Speed
R/red - Low Speed
SOURCE: diagram
ok i got it.
Please CLICK HERE and just browse the sub components and you'll get the wiring diagram..I have already selected your model in that
SOURCE: need a wireing diagram for
Often the wiring diagram maybe found in the console area or under the dryer top panel. Due to regional differences in electrical code and power requirement, wiring system hence the diagram may differ. Additionally, it would also differ if you are using a 4 wire outlet or a 3 wire hookup.
At this point, perhaps your best bet would be to seek the services of a qualified professional who is very familiar with the electrical/power system of your area as well as general wiring of dryers. Should you venture a DIY, pls post back power requirements/availability whether for a 240/120 or 110/110.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Ice maker out, I need a wiring diagram. GE model
I hope you are an electronics major. The ice maker uses the most complicated and heinous electrical theory available. What usuall goes wrong are those hairline contact arms they use. They have assembly tricks only surpassed by the inscrutible oriental puzzle boxes.
For about $150 you can get another.
SOURCE: need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
