Question about Fargo DTC400 ID Card Printer Package
Hi! How can solve a Headlift error message on a DTC-400 Card Printer
Error 103 headlift error fargo hdp 5000
erro 103 could cos by head voltage erro or head fit erro.
this could be a problem with the printhead lift or transfer roller headfit.
reset the printer and try again ...
Jan 05, 2013 | Fargo HDP5000 Thermal Printer
X5410 Dowon loading to my X5410
Disconnect the printer and uninstall all printer software. If you have the printer disk reinstall the software or download it from the manufacturers site. Then reconnect the printer.
the problem has occurred because drivers have become corrupt.reinstalling drivers will solve the issue
Jul 11, 2011 | Lexmark Office Equipment & Supplies
Error fargo hdp5000 # 218
can somo one help I have Fargo HDP5000, showing an error LAM2 HEADLIFT ERR 218
Apr 21, 2011 | Fargo HDP5000 Thermal Printer
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Ribbon mis-cue?
When you have a ribbon mis-cue, first remove the ribbon. Go to the printer driver, printing preferences, calibrate, sensors. Click sesors then send... You should hear 2 beeps. Put you ribbon back in and try to print again.
If you still have the mis-cue it is a belt issue all DTC400's made 2006 and prior have had this belt issue. I don't recommend fixing this yourself, send it to a authorized Fargo repair center. This way it is under warranty.
Jan 05, 2009 | Fargo DTC400 ID Card Printer Package
Error/ Head Lift Error
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Hi i have fargo dtc525 card printer i am using that printer scince 1 year, now not working error massage HOPPER 1 EAMPTY this type of message showing please tell me solution.
hopper 1 empty means that you do not have any cards in it. The printer has 2 hoppers, and your program maybe defaulting to hopper 1. Select hopper 1 and cards to it and that should solve the problem.
Nov 30, 2008 | Fargo DTC525 ID Card Printer
Device error 400
There is a few details we need in order to help you better solve your problem. Please let me know the following:
  1. What action on your Blackberry are you trying to do that gives you the ERROR 400 message?
  2. Are you trying to browse the internet whent his action happens or just any programs?
  3. Are you trying to use your phone under a shared work system?
  4. Are you on an individual plan or company plan?
  5. Are you able to do anything after that error message shows up?
  6. If you turn off your phone, take out the battery for a full minute, then put it back in, does that solve this error message?
  7. Is this a new error message or has this happened to you before?
Let me know the answers to these questions in order to better assist you with a solution. We're looking forward to your response!
Sep 30, 2008 | RIM BlackBerry 7290
Fargo DTC400 ID Card Printer Package Logo
49 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
