Question about KitchenAid Refrigerators
Our side by side unit's motor won't turn off and the temperature has remained constant. It might be just a fan stuck on. What do you recommend?
  • 17,970 Answers
Sound like the thermostat needs replacing
Posted on Aug 25, 2010
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
HAVE A WHIRLPOOL FRENCH DOOR THAT RUNS CONSTANTLY
Hello Georgia;
My name is Peter. I am a retired field service refrigeration technician.
It sounds like your unit is not dissipating the heat.
With your hand feel the front of the separator between the freezer and the fresh food section. Is it hot?
Ok, this is a simple fix.
You have a condenser coil like your car radiator that cools your engine. This is the same on your unit.
You have not provided a model number. Your model number is on a label on the inside wall of your fresh food section near the top.
Your condenser coil is located on the bottom of your unit.
This coil is either accessible through the front bottom toe plate or through a canister in the lower back of your unit. If this coil is plugged up with normal dust and hair it could make a difference as much as 40 degrees F.
But, you problem goes beyond that. The cooling coil not being able to dissipate the heat will cause the compressor to run constantly trying to meet the unit set temperatures.
So, The problem is: The condenser cooling fan is not working.
What to do:
1.) Do not unplug your unit.
2.) Pull your unit out to where you can physically get behind it.
You may have leveling screws where you will need to raise them by turning them counterclockwise. If you have a expensive kitchen floor protect it with cardboard.
3.) Remove the lower bottom cover.
4.) On the left had side is your condenser cooling fan. The fan may have been stuck due to grime. Moving the unit may have freed the fan.
5.) With a screw driver or something try to turn the fan blade clockwise.
6.) If the fan runs, you still have a bad fan motor.
7.) If the fan does not turn. Leave your unit pulled out. Take a general house fan and blow air under the bottom of your unit.
If you do not understand these instructions, please call me.
Peter
Glen Burnie, MD USA
443-306-1362
Jan 23, 2015 | Whirlpool Refrigerators
Ice machine , fan kicks on and off constantly
Hello Harold;
Your fan is not designed to run constantly. Your fan will turn on when the set temperature falls 10-20 degrees below set temperature, and will run until the unit is 10-20 degrees above set temperature.
1.) Clean your condenser coil. This coil removes the unit heat.
2.) Check your condenser fan to make sure it is running.
3.) Check the door gaskets. They may be crushed or worn, allowing warm air to enter your unit.
Dec 23, 2014 | Refrigerators
How do i dismantle the dashboard
Presuming your car is fitted with the automatic heating/cooling system.
There is only one fan controls the heating/cooling system the distribution from this to the various vents is controlled by a series of electronic flaps which open or close dependent on the temperature selected at the control unit.
If the motor is running and the drivers side is receiving cooling it may be a problem with the control unit or a flap has stuck open.
Replace the control unit first as the flaps are a citroen job.
Control unit is the bit with the temperature displays etc.
Apr 01, 2014 | 2006 Citroen C5 1.8
My frigidaire side by side model#GLHS37EHSB7 is making a constant beeping noise and the electronic temperature display isnt coming on. what could be causing this
Hi Julie, this is JK. Thank you for your recent post!
I see that your Frigidaire Refrigerator, GLHS37EHSB7, is constantly beeping but the electronic temperature display is not working. Generally, this could happen when you experience a power failure. I would strongly suggest that you either unplug or turn the circuit breaker off to the unit for about 30 minutes. Let the unit reset completely and try to use it as normal again. If this concern still continues, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Hope this helps!
Mar 19, 2014 | Frigidaire Refrigerators
Freezer motor will not turn on
Try cleaning the unit out and any coils you can reach (typically located near the bottom of the unit behind the toe grille). Do you hear the compressor running? The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. If you do not, the unit could possibly have a coolant leak or an issue with the internal sealed system including a faulty compressor, evaporate fan or main control board. Contact a professional move forward accurately.
For manualsonline.com
Jan 29, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
LG Model: LWHD1500ER - I would like the unit's compressor to remain on constantly. The temp guage seems to be off and shuts down the compressor. Can I bypass the temp guage to leave th ecompressor...
You can but the unit will have not control over temperature, and you can cause the unit to freeze up or slug the compressor w/ liquid refrigerant causing premature compressor failure. I would recommend replacing the thermostat if it is not holding proper temperature, but if dead set on bypassing it use a volt/ohm meter after unplugging it to find the normally open contacts and wire those wires together taking into consideration that the fan must run constantly with the compressor.
Sep 23, 2011 | LG LWHD1500ER Wall/Window Air Conditioner
I'm getting water in the ice dispenser. The
First, check to see if the evaporator fan is blowing in the freezer. A common cause for this problem is an air baffle that is stuck open, or closed due to frost buildup or a component failure. The air baffle is at the top of the wall between the freezer and the refrigerator. If you check for cold air coming through this vent, you will probably find that it is constantly open. A temperature sensor (thermistor) in the refrigerator normally detects temperature and a control board sends voltage to a motor to open and close this baffle properly to control refrigerator temperature. You could have a failed thermistor, failed baffle motor or a failed control board that is causing your problem as well.
Jul 27, 2011 | Maytag MCD2257HE Side by Side Refrigerator
Condenser fan motor runs constantly compressor stops but fan still runs
Don't know what type of unit you're talking about but usually there's a relay or contactor to turn the fan on and off. Sounds like it may be stuck closed. The points may be pitted. Best to change.
Jul 15, 2010 | Heating & Cooling
Refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
Oct 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
