Question about Kodak EASYSHARE Z1285 Digital Camera
My zoom no longer works. The camera shuts itself off when I try to zoom. May have got a little sand in it at the beach.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 25, 2010
I own a Samsung PL200 camera. However, I believe a bit of sand got into it and now the zoom no longer works. Not only can I not zoom in or out, but when I view my pictures when on the camera, I can not...
Sounds like a broken zoom switch to me. Sorry, but there's nothing much you can do about it. You will have to give it to a camera technician, because it's most likely a hardware problem and the camera has to be disassembled to see what's what. They are small mechanical switches and they use to break sometimes. Sand shouldn't affect it, unless some sand got inside the switch itself (don't see this often). I have repaired more than 1000 cameras and seen many various problems, so I can imagine. ;-)
Tom
Mar 05, 2011 | Samsung PL200 Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Kodak C330 [lens error 14]
Hi Jesse, thanks for coming to FixYa.
The problem your having is that sand and/or dirt gets in the lens mechanism of the camera. When the little cog inside gets sand in it, it prevents it from moving. It is what causes 95 percent of all lens errors. The other 5 are when the retaining pins get misaligned and don't go back in the holes. Mis aligned pins happen alot of times when you drop it with the lens extended, so let's go with the easy one first.
Take an air compressor (or borrow a friends) and put the nozzle up to the space in between the lens and and the camera. Blow it out real good. It may take a couple of tries, but it should free it up.
Let me know if that helped, and feel free to rate my answer.
Rob
Mar 04, 2009 | Kodak EasyShare C330 Digital Camera
The Beach
You may want to call Olympus Customer Service and discuss their repair process and procedures for sending the camera in to have the lens assembly cleaned. Their telephone number is 800-622-6372 option 2 and then option 3
Jan 09, 2009 | Olympus FE-190 Digital Camera
Cant zoom on my DSC-W80 sony cybershot after droping it in the sand at the beach
If you found good information in my solution, please be sure to rate it! Thanks!
Oct 25, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Zoom error
you may be true that sand must be creating this problem, as this happens very often. the sand enters into the lense assembly, creating friction in the movement. if this has happened total dismantelling and cleaning of the lense assembly will solve the problem, but that has to be done by an expert at the repair shop.
Aug 17, 2008 | Olympus Camedia C-350 Digital Camera
Shuts off when i try to zoom.....
I was also having a similiar problem with my z1275 and tried the "vacuum" thing. BINGO! It worked, and I was about to send the camera back to Kodak for servicing. You saved me money.
What did I do?
I turned my vacuum on, stuck my lense into the vacuum tube, zoomed all they way IN and then turned the vacuum off. My camera now works perfectly.
Before using the vacuum, I was only able to zoom about 50% before the camera would turn off. Thanks for your help.
Jul 29, 2008 | Kodak EasyShare Z1275 Digital Camera
Sony Cyber-Shot Lens!
I really don't know a lot about this stuff..but if I were you I'd go and have it professionally cleaned right away. You don't want sand in their messing up the camera.
Jun 19, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
My Casio camera failed to the sand
You are going to have to send that into the repairs dept for Casio. Sand is a killer on these cameras. Call the repairs center at 800-706-2534 and then keep choosing option 1. If they tell you to call tech support first just lie and tell them that you already talked to them. LOL
Jun 30, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
