Question about Toro Garden
Lawn nmower starts then stops like it is out of gas
  • Toro Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor. When you rebuild your carburetor keep in mind that the float has to be level when you turn the carburetor upside down with the bottom of the carburetor still removed.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 25, 2010
I have a 6.5 hp toro lawn recycle mover , that will start, but will not continue to run but a few seconds
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Mar 16, 2016 | Toro Power Lawn Mower
Why does my lawn mower stop suddenly. I have good gas, new plug and new air filter. The oil level is at or just below full.
try loosening the gas cap. Clogged Gas vents seem to be getting very common since the use of Ethanol gas
May 28, 2015 | Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
6.25 190 cc mower wont stay started
your running out the gas in the carb out you need to rebiuld the carburator probably dirt in the carb from bad gas
Jul 22, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Starts, then stops
All mowers have a low level oil cutoff. Fill oil with 30w. Ensure fresh gas. Always use Stabile.
Jul 06, 2012 | Toro Power Lawn Mower
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Oil plug
There is a drain plug in the bottom of the engine. It has a square hole in it that a 3/8 socket extension will fit in. It may be hidden by the belt cover if you can't see it. Dwain
Jun 03, 2009 | Craftsman Garden
Garden Logo
189 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
