Unable to install WINDOWS XP on Core i3? Spec: motherboard GA-H55M-S2H processor Core i3 DDR 3 RAM
  • 104 Answers
Change hard disk mode to IDE or HCI
Posted on Aug 25, 2010
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
My Intel Core i3-530 Toast up 5 motherboard MSI H55M-E33. Im so lucky it was under warranty(RMA).. now question.. How to prevent processor from toasting the motherboard?? this is new to me.. any tips will...
Overheating is always a bad contact between the processor and the heat sink, or overclocking. Always check that there is nothing getting in the way of the heat sink making good contact. Things getting in the way happens a lot. After making sure there is a good contact surface, use heat sink compound.
You might be better with an Asus motherboard if it happens again.
Nov 15, 2017 | MSI H55M-E33 Motherboard & Intel Core i3...
I installed graphics to my gigabyte ga h55m s2h but keep shutting it down. Is there any jumper that I need to set it up?
Hi
The graphic driver is not support, please download the correct driver to your system, or Click hear to download or update your driver.
Jun 05, 2011 | Gigabyte Computers & Internet
Installed a new gigabyte h55m-s2 rev 1.3 in my system. BIOS is F4. Installed 2GB of EVM RAM, Core i3-540 processor, 450W PSU. When I press the Power button, the system beeps once. The monitor shows the...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Apr 02, 2011 | Gigabyte GAH55MS2 Motherboard
I lost audio with my computer Motherboard MSI h55m-e33 CPU: Intoel Corei3 530
Try installing the latest audio driver.
You can download the drivers from MSI WEB support site,select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Feb 02, 2011 | MSI H55M-E33 Motherboard & Intel Core i3...
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Hi, I am planning to buy lenovo think pad laptop having core i3 processor, loaded with DOS. I got some market feedback that intel core i3 does not support window xp professional. Why i am so much...
Hi Sanjeev,
Just about a month back I purchased a Lenovo laptop having Intel Core i3 processor loaded with DOS.
I then installed Windows XP SP3 32-bit and there is absolutely no problem whatsoever with the compatibilty. Also, all the device drivers for Windows XP are available on Lenovo support website.
So, there should be no problem to install and run Windows XP on this laptop.
Wish you all the best. Thanks for using FixYa.
Oct 17, 2010 | Microsoft Windows XP Professional
Ga-h55m-s2h board not booting, nothing on screen . cpu fan spins and everything is indicating activity. Post give 1 long beep and 2 quick. phase leds 1 and 2 green, 3 orange, 4 red
Just had the same problem, same board. This mb does not play well with all types of RAM. I had a single 2gb Patriot dimm and it did the exact same thing, removed the RAM and it would boot but no screen. Replaced the single dimm with 2 - 1gb dimms and it booted right up with no problem. Hope this helps.
Mar 10, 2010 | Gigabyte Computers & Internet
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
