Question about Sony Cyber-shot DSC-S600 Digital Camera
Power switch stuck down on my Sony DSC-600 digital camera , can I fix this?
  • Tony Watts Aug 26, 2010
    Thank you Apprentice, you were spot on. Having taken the surround off I can see the white plastic insert is broken. Can you buy the insert or the surround? Thanks again
  • 5 Answers
The power switch on this camera breaks in half sometimes after a while. Either replace the entire central plastic band of the camera on which the power switch is located or . . . . You can drill a small hole in the plastic and use a paper clip to turn the camera ON and OFF. A bit of a Rub Goldberg fix but it works. See picture for location of the hole. It lines up with the small switch on the circuit board. Power switch stuck down on my Sony DSC-600 digital - 0d405cb.jpg
Posted on Aug 25, 2010
Testimonial: "I appreciate the speedy response and particular the suggested fix"
  • scriverb Aug 26, 2010
    You cannot buy the small white plastic button but you can find the "Surround" or plastic strip piece that houses the buttons for the Power and Shutter. You can find them at times on Ebay. Or buy a parts camera on ebay for $25 and swap out the part needed. This is what I have done many times before. Or, as I suggested just drill the hole and use a paper clip . . . I use these cams for trail cameras and don't need to turn them on and off manually but rather by wiring them to a control board so this works for me. Good luck.
  • Tony Watts Aug 27, 2010
    Thanks scriverb, I'll keep a look out on ebay for the "Surround". The camera belongs to a lady friend and I can't quite see her even attempting the paperclip solution. Thanks again from the UK for sharing this insight into the repair of this Sony camera
    Tony
Power button stuck down on my sony cyber shot dsc s600
Possible that this is a mechanical failure and the switch is broken or out of place. Remove the battery and check the charge, if this seems fine then replace and tap the camera upside to see if the buttons resets.
If not the camera must be taken out, try to open ONLY if you have the correct tools and do not try to open otherwise to damage the unit.
Best option is to take an opinion from Sony for estimation.
Jun 25, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
My sony cybershot mpegmovieVX dsc-92 fell down and it's shutter is stuck inside. I cannot go buy a new camera OR go get it fixed. How do you fix it I need help :( urgently
Sorry but usually when the camera lens is forced shut, the gear mechanism will get out of sync. Usually even if it will open, you will receive a Lens Error
Jun 25, 2011 | Sony Cyber-Shot DSC-P92 Digital Camera
My Sony cyber-shot DSC-P100 camera will not shut off. The only way to power-down is to remove the battery. Any suggestions as to how to fix it?
You may have a bad on/off tack switch, from your description the camera functions normally, but you can not shut it down. One possible solution is to get a can of electronic contact spray cleaner for pods, Radio Shack carries in stock, or service shop. If you can access the button directly all the better, if this fails you may need a new tack switch.
Feb 01, 2011 | Sony Cyber-Shot DSC-P200 Digital Camera
Stuck power button on my Sony cybershot dsc-s600
Hi!
Yes, power buttons do break on these cameras. Contact your local Sony service center and see how much will it cost to replace the top panel. If they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Jul 19, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Power button stuck
The power-zoom-shutter top case assembly is faulty. You can replace this part.
Mar 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-P200
i had this problem, so bought faulty camera from e bay and harvested the switch from it and my one works sweet as now ..
took me about 15 mins to do the job
Aug 15, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
I have cam sony dsc-s650 " dark screen "
get a broke one off ebay and use the flash circuit and mainboard from it. or go to www.digitalcamrepair.com for help.
May 05, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Power Button is stuck down
sir,this is common for this model. internal micro switch conecting lever is broken u replace
Jan 03, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Power button stuck down for good
I also have the same problem with my camera. the power switch is pushed down and won't turn on. it is stuck in the down position and i cannot use it. The camera was bought last August in New Jersy and is now with me in the Philippines
Nov 06, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
63 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
